Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8339 |
So what's the fault that shows to make the system inoperative..?? Pete
2nd Nov 2016 10:11pm |
Buff Rio Member Since: 29 Dec 2012 Location: Banstead Posts: 36 |
The fault says, reservoir pressure static when filling . So what does that mean exactly ? 2006 3.0 TD6 Vogue Black - sold
2nd Nov 2016 10:20pm |
It means exactly what it says, the pressure sensor in the tank is not registering an increase in pressure when the pump is running..
2nd Nov 2016 11:39pm |
Hi Pete
3rd Nov 2016 6:52pm |
It sounds like either the compressor is worn out and can't get to pressure or the pressure sensor is worn out and can't read the pressure......
4th Nov 2016 2:26pm |
Ok Pete thanks, will change the sensor first. Is that an easy job, I tried to look for it and there looked liked there is plastic cover in the way. Do I just remove that cover then the sensor is in the end of the reservoir ? any tips greatly appreciated.
4th Nov 2016 3:21pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
There is a thread about it in the Wiki, have a read of this http://www.fullfatrr.com/forum/topic18252.html
4th Nov 2016 6:06pm |
Rangegeek Member Since: 21 Oct 2016 Location: Pittsburgh Posts: 8 |
Hello, can anyone help with sending me a link for a software to load on a pic that will allow to reprogram the steering angle sensor on a 2005 RR Hse thank you much |
8th Nov 2016 11:29pm |
Best to start your own thread rather than hijacking someone else's... but seeing as you ask, there isn't any you can download for free, you will have to buy a Range Rover specific diagnostic tool. Gap IIDtool is the best... Link in my signature below... Pete
9th Nov 2016 12:42am |
Thank you and sorry for invading I thought it was related :0 |
9th Nov 2016 12:47am |
Steering angle sensor has nothing to do with the suspension....
9th Nov 2016 1:14am |
Blankone Member Since: 10 Aug 2016 Location: St Helens Posts: 21 |
Steering angle sensor does interact with suspension, had it on a 04 model (the red car in the pic's in my gallery) one of the 4 leaf contactors on the track inside the sensor had snapped off, couldn't set steering angle so suspension wouldn't work, BMW X5 use the same senor and are cheaper than buying from LR. |
9th Nov 2016 5:31am |
Yes I tried the steering reset, my mechanic said that he plugged a scanner in and came up with communication error so I bought one and he replaced but he doesn't have the software to reprogram it
9th Nov 2016 12:53pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
If your mechanic doesn't have the tools to do the job then look for an independent LR mechanic that does. Then hopefully all of your problems will go away.
9th Nov 2016 1:36pm |
