Home > Technical (L322) > Error Code: P0489-00
Page 2 of 3 <123>
Realist
Wales
So the quicker I get the EGR valves changed the better the engine and my pocket will be. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #411327 29th Oct 2016 7:27pm
sako243
The issue I could see as well having replaced mine myself is that they sometimes fall to pieces internally. Depending on how it falls apart this may get sucked into the turbo although that's a small possibility.
If you're handy with a spanner then its not a complicated job just fiddly. There's a good write up on here by ebajaema which I followed along with the workshop manual where necessary (although it's not required but I was doing it between other jobs and chaotic work so took me a couple of weeks). Worth changing water pump while you're there too. Ed
Post #411335 29th Oct 2016 8:56pm
Realist
Wales
Why water pump? Range Rover quotes.....
Post #411347 29th Oct 2016 10:09pm
sako243
Sorry thermostat housing. Because by the time you've removed the EGRs you've done all the work to gain access to it. If you've got some sign of leaks in the valley then it's worth changing as the O rings have a tendency to perish. Ed
Post #411351 29th Oct 2016 10:39pm
miggit
Rolling Eyes I wouldn't have thought this possible as they are after the turbo.. so the air flow is from the turbo to the EGR Via the intercooler (if it has one), for bits of the EGR to end up in the turbo, the turbos have either got to run backwards or, more likely, end up in the exhaust side... in which case they have already gone through the engine Shocked
As Mikey said, turbo failure is more likely from overspeed due to a blown hose, or, restricted oil supply... which could be caused by the EGR putting too much soot in to the induction side of the engine..... A diesel engine is dirty enough without dumping extra soot in to the heads.... Progress? Yesterday I couldn't spell Engineer... Today I are one!
Post #411361 30th Oct 2016 12:10am
Realist
Wales
So after all the head scratching above and answer seeking....... Can the car be driven slowly ie to the garage to be fixed and when the EGR valves are fixed what's the chances of the turbos being effected or going at a later date. Range Rover quotes.....
Post #411396 30th Oct 2016 10:49am
sako243
Fairly minimal I would have thought. Personally I'd only drive it to the garage and no other runs. Whilst I think the chances of damage are minimal if something does go then the bill will go up by at least one extra zero I would have thought, if you're lucky! Ed
Post #411397 30th Oct 2016 11:04am
rangie47
realist - how do you drive,
egr problems can also start if you drive it like ( miss daisy ) as my indie called it.
i.e gently and short trips ,they dont like it Big Cry
give it a dam good thrashing once in a while 2007 tdv8 se ,stornaway grey
Post #411400 30th Oct 2016 11:12am
miggit
I didn't know these had EGR's Rolling Eyes
Post #411404 30th Oct 2016 11:21am
Realist
Wales
Its the misses car she drives like miss daisy back and fro work which is 2 miles there and 2 miles back daily and up her mothers which is another 1 miles max.
So the car gets driven 5 miles a day at 30mph and when I'm in it I drive like STIG flat out foot to the floor. Range Rover quotes.....
Post #411406 30th Oct 2016 11:37am
miggit
Whistle Leave it in low range...that should blow the cobwebs out Shocked Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #411408 30th Oct 2016 11:45am
Realist
Wales
Yeh and she'll thrash it at 3mph LOL Range Rover quotes.....
Post #411409 30th Oct 2016 11:56am
Realist
Wales
Update.
We had RAC garage cover and they said sorry EGR valves are not covered plus the garage the RAC said yo take it to said sorry we're not touching it see a specialist.
So FFRR is now with a LR specialist in Caerphilly and they quoted so far close on £1000 plus to change the EGR valves
Haaaaaaaaaaaaaa Range Rover quotes.....
Post #412422 6th Nov 2016 7:48pm
miggit
Whistle could have got a nice set of shiny spanners, 2x EGR and a IIDtool for that, and still have enough to go to Mac Donalds for a Happy Chappy Meal Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #412432 6th Nov 2016 8:07pm
Realist
Wales
Already got the spanners and IIDTool just do idea how to change them or the time. Range Rover quotes.....
Post #412435 6th Nov 2016 8:13pm
Page 2 of 3 <123>
