Home > Technical (L322) > Error Code: P0489-00 |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
So the quicker I get the EGR valves changed the better the engine and my pocket will be. Range Rover quotes.....
29th Oct 2016 7:27pm |
Why water pump? Range Rover quotes.....
29th Oct 2016 10:09pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 609 |
Sorry thermostat housing. Because by the time you've removed the EGRs you've done all the work to gain access to it. If you've got some sign of leaks in the valley then it's worth changing as the O rings have a tendency to perish. Ed |
29th Oct 2016 10:39pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I wouldn't have thought this possible as they are after the turbo.. so the air flow is from the turbo to the EGR Via the intercooler (if it has one), for bits of the EGR to end up in the turbo, the turbos have either got to run backwards or, more likely, end up in the exhaust side... in which case they have already gone through the engine As Mikey said, turbo failure is more likely from overspeed due to a blown hose, or, restricted oil supply... which could be caused by the EGR putting too much soot in to the induction side of the engine..... A diesel engine is dirty enough without dumping extra soot in to the heads.... Progress? Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
30th Oct 2016 12:10am |
So after all the head scratching above and answer seeking....... Can the car be driven slowly ie to the garage to be fixed and when the EGR valves are fixed what's the chances of the turbos being effected or going at a later date. Range Rover quotes.....
30th Oct 2016 10:49am |
Fairly minimal I would have thought. Personally I'd only drive it to the garage and no other runs. Whilst I think the chances of damage are minimal if something does go then the bill will go up by at least one extra zero I would have thought, if you're lucky! Ed |
30th Oct 2016 11:04am |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
realist - how do you drive,
30th Oct 2016 11:12am |
I didn't know these had EGR's
30th Oct 2016 11:21am |
Its the misses car she drives like miss daisy back and fro work which is 2 miles there and 2 miles back daily and up her mothers which is another 1 miles max.
30th Oct 2016 11:37am |
Leave it in low range...that should blow the cobwebs out Yesterday I couldn't spell Engineer... Today I are one!
30th Oct 2016 11:45am |
Yeh and she'll thrash it at 3mph LOL Range Rover quotes.....
30th Oct 2016 11:56am |
Update.
6th Nov 2016 7:48pm |
could have got a nice set of shiny spanners, 2x EGR and a IIDtool for that, and still have enough to go to Mac Donalds for a Happy Chappy Meal Yesterday I couldn't spell Engineer... Today I are one!
6th Nov 2016 8:07pm |
Already got the spanners and IIDTool just do idea how to change them or the time. Range Rover quotes.....
6th Nov 2016 8:13pm |
