![]() | Home > Technical (L322) > Engine bay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
have a look at some front end conversion threads , they will show the front stripped down.. ... - .- -.
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
Tried a few, but its really the little brackets etc i need to see. The conversion pages do not show rhat sort of area or detail. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I've got the same model as you, I could pop out tomorrow and take a few pics for you. Give me an idea of where in the engine bay you would like them taken and I'll give it a go..
Thats a difficult one, i have dropped the engine and box back in and am about to refit the engine wiring loom amd the front rad etc etc.
Hi Phil,
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If you need more I have around 300 pictures from when I did my vanos and timing chain guides project a few weeks back but I won't be back at my PC until Saturday.
Thanks both of you, i have sent pms and i hope that will allow me to finish.
I had around 50 bags with the white strips on and wrote on where they came from as I too have had projects in the past that have overrun and everything looks really simple when you take them off....
This may be of some use until we can get you some more fots
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 ![]() ![]() ![]() |
I had one image in gallery.
Thanks,
I have just done the full cam chain and guides job and i would not recommend taking out the engine !!1
As i said i was pulling anyway, but by the time you have taken off the bits to do the chains, all is left is the belhousing and torque converter. Amd lifting it out of course. Which is maybe 30 minutes. I am spoilt with a hydraulic powered engine crane, but it did come out in a few minutes.....
That is a good call for doing the torque converter at the same time, I did replace mine at 108K and all the other jobs that need doing like valley pan, pcv pipework and cam covers it would be easier to take the engine out rather than the transmission down if you have a lift as you say.
