Home > Technical (L322) > High steering load off throttle |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 |
Our FFRR has had this issue since we got it 6months ago. Coming into roundabouts and when manoeuvring the steering gets intermittently heavy.
20th Oct 2016 7:58pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Silly question but have you checked the power steering oil level...??? Pete
20th Oct 2016 8:02pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
Hi,
20th Oct 2016 8:20pm |
When you experienced it did you get error codes in the BCM? Or did you just replace and the problem went away?
20th Oct 2016 8:24pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I had an issue, trying to fit a dash cam, and get a supply from the fuse box, in glovebox. I piggybacked off a fuse, and immediately, my steering was heavier, better at speed, but hard to do slow hard turns. I removed piggy back wire, and it went better. It turned out to be the servotronic supply.
A small amplifier for an iPod jack wired into something in the centre console, can't remember exactly what now, but the register before I put that in. |
20th Oct 2016 8:26pm |
Hi,
That's a useful data point then, servotronic valve with no codes.
20th Oct 2016 8:28pm |
Just to close this out.
23rd Oct 2016 8:47pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
I had the same on my 2004 car, pump needed to be replaced. Only Range Rovers since 1988 |
24th Oct 2016 1:35pm |
