Home > Technical (L322) > High steering load off throttle
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Our FFRR has had this issue since we got it 6months ago. Coming into roundabouts and when manoeuvring the steering gets intermittently heavy.
I've searched the forum and found three failure modes so far:
Servotronic valve failing - as per Stan's experience http://www.fullfatrr.com/forum/topic7311.html
BCM failing - http://www.fullfatrr.com/forum/topic37139.html
PAS Pump failing - http://www.fullfatrr.com/forum/topic33412.html
I've got no codes stored in the BCM, but can't tell from my search is if anyone has had a servotronic or BCM issue without a code being stored or if it's most likely that its a pump fault?
Thanks
Post #410031 20th Oct 2016 7:58pm
Silly question but have you checked the power steering oil level...??? Pete
Post #410032 20th Oct 2016 8:02pm
ndg
Not silly at all, but yes first thing I looked at unfortunately. I've had BMW's in the past, so use to leaky PAS systems!
Post #410033 20th Oct 2016 8:05pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
Sounds like the steering transducer, when it starts to go you get intermittent heavy steering.
Part number QFW500040.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #410035 20th Oct 2016 8:20pm
ndg
When you experienced it did you get error codes in the BCM? Or did you just replace and the problem went away?
Thanks
Post #410036 20th Oct 2016 8:24pm
johnboyairey
I had an issue, trying to fit a dash cam, and get a supply from the fuse box, in glovebox. I piggybacked off a fuse, and immediately, my steering was heavier, better at speed, but hard to do slow hard turns. I removed piggy back wire, and it went better. It turned out to be the servotronic supply.
Do you have any wiring add-ons?
New head unit?
Post #410037 20th Oct 2016 8:24pm
ndg
A small amplifier for an iPod jack wired into something in the centre console, can't remember exactly what now, but the register before I put that in.
Post #410039 20th Oct 2016 8:26pm
UK Marine
Hi,
No I didn't get any error codes and when I fitted the new one the steering was back to nice and light again.
Simon
Post #410040 20th Oct 2016 8:26pm
ndg
That's a useful data point then, servotronic valve with no codes.
Thanks Thumbs Up
Post #410042 20th Oct 2016 8:28pm
ndg
Just to close this out.
Now fixed, the culprit was the PAS Pump.
Hopes this helps others in the future.
Post #410441 23rd Oct 2016 8:47pm
CS
I had the same on my 2004 car, pump needed to be replaced. Only Range Rovers since 1988
Post #410502 24th Oct 2016 1:35pm
