![]() | Home > Technical (L322) > Aux Heating |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
Just blowing ambient temp air this morn with no warmth.. |
Got the FBH to start firing up including clicking and small puff of smoke but it then shut down with a low crackling sort of noise. Tried it multiple times but did the same thing.
krisleeds Member Since: 19 Oct 2014 Location: leeds west yorkshire Posts: 60 ![]() ![]() ![]() |
I feel your frustration.
Thanks Kris. Misery loves company |
Ha im the same. If it's fitted and supposed to work i will try my best to get it working. I try every morning.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
May not work, but set your heater controls to a highish temperature and pull and replace the fuse. Apparently you need to reset after three failed attempts. Use the screen controls first. Leave the remote till you have got it working.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
I am getting the same problem with my FBH.
-20 Celsius.
As I mentioned above, + 1 for vehicle battery charge state. I take it also that you are aware that the Park Heater will turn off if the ignition is on?
thanks. kept mine on battery conditioner all day/overnight just in case and new batteries in remote..also try manual start on console a number of times.
Can you smell any fumes by the front left wheel arch? Any smoke coming out ?
I can smell the fumes but only a small puff of smoke after it shuts off from an aborted start 😔 There is definitely a plastic creaking sound when it aborts.. |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
its that time of year again
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
These units are real simple. If your getting the clicking and a smell of fuel, all thats left is the glow plug. The burners have a gauze in them that the fuel gets fed into which is then ignited by the glow plug. Ill wager the gauze is clogged or you have a duff glow plug. No7 - 2003 V8 Vogue |
