![]() | Home > Technical (L322) > Aux Heating |
krisleeds Member Since: 19 Oct 2014 Location: leeds west yorkshire Posts: 60 ![]() ![]() ![]() |
What about the random no clicking tho. Then it's not so simple 😂 |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 ![]() ![]() |
Just read this trail and it all feels very familiar. My experience was similar last winter. The stuff on the 75 and ZT forum on the link above is great and the symptoms you describe are just what I had a year ago. After removing the heater I stripped it as per the on line guides and after cleaning and refitting got the thing to work. Unfortunately what it really needed was a n w glow plug to work reliably but a clean and seeing it work once made it worth shelling out £50 for a service kit. (takes about 20 mins with the suspension set high to get the wheel arch liner out and remove the heater now I am practiced)
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 821 ![]() ![]() |
My FBH sprang into life !
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 492 ![]() ![]() ![]() |
Wow, well done. Mine still winds up but then it crackles and and shuts down 😔 |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi mines working but not sure if it's as warm as it should be , do you need to leave it on for the full 30 mins ? 2015 4.4 AB
Yes, is best
Thanks , I'll stick with 1/2 hour then 2015 4.4 AB
Finally got my FBH working..it just needed re-priming and now works a treat! |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
How do you re-prime them? Mine seems fine but gets as far as a steadily increasing speed of clicking then shuts down.. |
