Home > Technical (L322) > Aux Heating
Page 1 of 3 123>
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Aux Heating
Hi Guys, put some new batteries in my Aux heater remote for the winter and tried it out but nothing happens really. I've never seen it run since buying the car around a year ago and have studied the owners manual. I even tried the manual activation button within the car but nothing happens. Any thoughts on fault finding?
The car is a Dec 06 3.6 V8 Diesel Vogue.
Many thanks in advance!
Post #408137 7th Oct 2016 3:33pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I believe aux heating only activates over 15 degrees ambient. Is it the original fob? They do need pairing with the car and even if original may have lost pairing at some change of battery etc.
Not sure about the manual function other than the 15 degree bit above.
just a thought. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #408138 7th Oct 2016 3:57pm
Weegie
Park heating will only come in if ambient is less than 16 C. Cooling only if over 16 C. If you have changed the battery then, as suggested, you may well have to pair the remote again. First thing to try.
A forum search will explain how to.
How the FBH works is in WIKI. John
GAP iiD BT-Sold
Post #408152 7th Oct 2016 5:06pm
Jase71
Okay, the latest is I have put new batteries in the remote, waiting until the temp was below 16 deg C, pulled the fuse to resync but the result is nothing happens with the heating. I get a green light on the remote for a few seconds and then that's it.
Is there anything else I can do to get the system working? Nothing happens when I press the manual activation of the system in the car either Crying or Very sad
Thanks in advance!
Post #408975 12th Oct 2016 12:27pm
Pulling the fuse doesn't seem to work on post 2006 cars , so find the receiver unit in the right rear where you will find it on the back of the mounting bracket and sync your remote by pulling out the power lead . 2008 MY Supercharged
Post #408986 12th Oct 2016 1:04pm
Jase71
Thanks Axle, but how do I find out if the FBH itself is faulty?
Post #408998 12th Oct 2016 1:32pm
Weegie
Have you tried running it from the display screen? John
GAP iiD BT-Sold
Post #408999 12th Oct 2016 1:34pm
Jase71
Yep
Post #409001 12th Oct 2016 1:35pm
Weegie
and? John
GAP iiD BT-Sold
Post #409002 12th Oct 2016 1:36pm
Weegie
Just re-read your first post. Suggests your FBH is broken. Embarassed John
GAP iiD BT-Sold
Post #409004 12th Oct 2016 1:38pm
Jase71
Manual Button just goes green then red for a second and nothing happens..
Post #409005 12th Oct 2016 1:38pm
Jase71
Is there a fuse for the fbh just to check the obvious😎
Post #409007 12th Oct 2016 1:40pm
Weegie
Not sure if it's the same for your MY but on mine fuse 59, 20 amp.
PS. Passenger compartment fuse box. John
GAP iiD BT-Sold
Post #409011 12th Oct 2016 1:52pm
Jase71
Just checked and fuse is fine Crying or Very sad Have no idea where to fault find next!
Post #409017 12th Oct 2016 2:01pm
Jase71
Update, pulled fuse 56 and then did system reset diagnostic test and now the fans are running when I press manual and via the remote. Does the fbh not turn on unless ambient temp is colder?
Post #409030 12th Oct 2016 3:16pm
Page 1 of 3 123>
