Home > Maintenance & Mods (L322) > Which Oil? 4.2 S/C
RuthlessGK
United Kingdom 2005 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Which Oil? 4.2 S/C
Good Morning All,
Which is a good quality oil for the 4.2 S/C? I was looking at getting the Mobil Super 3000 as im sure i read someone on here used that. The engine has only done 74500miles approx so wanting to keep it as sweet as possible. I was just looking on the OpieOils website and dont want to spend more than £30 for 5l. I was planning on getting 10l in total and saving the rest in case of top up etc.
Cheerz,
Zaff Current Cars -
FFRR L322 4.2 Supercharged 'Bonatti Grey'
Mercedes C270cdi
Post #407501 3rd Oct 2016 8:33am
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I looked into this a couple of weeks ago and for me it came down to the Mobil 3000 vs Castrol Magnatec 5W30 A5.
The Mobil is cheaper but the Castrol (with the "Stop-Sart" branding) has the newer spec. I went for the Castrol.
The cheapest I could find was from Neilsson CDG via Amazon at £53.99 for 2 x 4L. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #407577 3rd Oct 2016 6:44pm
So long as it meets the right ford spec you should be ok.
WSS-m2c913-b is the right spec for the 4.2 sc (and also the 3.6 tdv8)
This is an easy spec to find. Some of the other ford specs are tricksy. Shell helix do a match, though possibly not the hx oil as it is a semi synth.
Don't just bung in any 5w30 make sure it is the right spec oil. There is nothing that can't be fixed with a hammer😜😜
Post #407601 3rd Oct 2016 8:33pm
RuthlessGK
Looking on Opie Oils for that special and found -
Fuchs Titan XTR
http://www.opieoils.co.uk/p-991-fuchs-tita...e-oil.aspx
Shell Helix HX7
http://www.opieoils.co.uk/p-69317-shell-he...e-oil.aspx
Fuchs Titan Fully Supersyn F
http://www.opieoils.co.uk/p-84114-fuchs-ti...e-oil.aspx
Basically which one is the best up to £30 on
http://www.opieoils.co.uk/c-698-ford-wss-m...er=[Sort=1*ava=0]&
Cheerz
Zaff
That Fuchs XTR seems an absolute bargain btw Current Cars -
Mercedes C270cdi
Post #407609 3rd Oct 2016 9:04pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Mmmm, Magnatech is rubbish and personally I wouldnt use the Mobile either.
Cheap and quality are not two words that work well for engine oils.
Full synthetic for your FF is the way to go, its once a year job unless you are doing a lot of milage.
Post #407611 3rd Oct 2016 9:14pm
RuthlessGK
So out of them which one would you go for.
Also what do you use pal? Current Cars -
Mercedes C270cdi
Post #407614 3rd Oct 2016 9:25pm
RR P38
I use Valvoline Syn power XL III.
You have a highly stressed (tuned) engine, Castrol Syntech is specified.
If you use semi synth or worse still mineral oil I would suggest halving the service interval.
Post #407622 3rd Oct 2016 10:07pm
RuthlessGK
I was only going to get the fully synthetic stuff. Just stuck as to which choice to go for. Valvoline are good as well so can't argue with your choice pal Current Cars -
Mercedes C270cdi
Post #407625 3rd Oct 2016 10:35pm
RuthlessGK
Just had a look in the handbook and it just says use a 5w30 oil meeting specification ACEA A1 or A3 or API SJ or SL.
Why couldn't they say they recommend Castrol X Current Cars -
Mercedes C270cdi
Post #407642 4th Oct 2016 6:01am
RuthlessGK
I have narrowed it down to the following 2 with the help of Opie and Oil Finders lol -
Mobil Super 3000
http://www.opieoils.co.uk/p-69360-mobil-su...e-oil.aspx
Fuchs Titan SuperSyn
Anyone else that would like to chip in with their thoughts. I have chosen all of the above on the specs of meeting the following -
Engine oil - V8 Petrol Supercharged vehicles
Use a 5W/30 oil meeting specification ACEA: A3
(with API SL or SM).
Land Rover WSS-M2C913-B preferred(This has now been superseded by WSS-M2C913-C)
Cheerz in Advance
Zaff Current Cars -
Mercedes C270cdi
Post #407678 4th Oct 2016 11:48am
RuthlessGK
To close the thread. I ended up going for the Fuchs Titan.
My choice after reading the specs and doing my research.
Many Thanks to all your help.
Big shout out to Opie Oils as they did beat the price I found somewhere else.
Zaff Current Cars -
Mercedes C270cdi
Post #407708 4th Oct 2016 4:42pm
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks for the info, I followed suit and ordered the Titan Synth plus K&N oil filter from Opie ( recommended, quick delivery free cos over £50 order) and changed the oil yesterday, fairly easy with her up on ramps on drive, once trays removed, but boy does it gush out, luckily was prepared but still managed make mess ! Convinced engine sweeter now,( mind the black stuff that came out didn't look like it had been changed when I was told it was)!
All in all good job and thread. Thanks OP
Post #409056 12th Oct 2016 6:37pm
RuthlessGK
Glad I could help. I had to get mine done at a garage for warranty purposes but big shout out to Elite Land Rover.
Engine sounds smoother even though the old oil was only in for 3k miles.
Zaff Current Cars -
Mercedes C270cdi
Post #409123 13th Oct 2016 10:06am
Jupiterrover
United States 2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I find using the Form A Funnel makes no mess whatsoever. One of the best accessories I have bought. I bought mine on Amazon.
http://www.formafunnel.com
Post #409139 13th Oct 2016 11:55am
Mulcher
What a brilliant idea, I'm going to get one for the workshop. Many of the Briggs-engined ride-ons have an oil drain plug situated inboard of the chassis which means oil can run back under the engine where it drips out and contaminates the drive & deck belts. I've had to shape drip-trays cut from old oil cans and tilt the mowers up at the opposite side to prevent this – but it all takes more time and adds to my already well-developed irritability quotient.
Oops, sorry for the thread hijack Embarassed 2006MY 4.2 SC
Post #409152 13th Oct 2016 2:04pm
