![]() | Home > Technical (L322) > Inactive suspension and icarsoft |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Tel, I'm down that way next weekend if it's any help.... |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
I bought an icarsoft for the same reason - lack of funds and suspension not working. It cleared it without a problem. And I paid £85 on eBay. I figured that if I use it three times rather than going to the local garage I'd be in credit.
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
I've had the same in an ASDA carpark. Drive off park somewhere turn off an then restart message gone, switch light back. |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Pete your a diamond. Thanks so much, may take you up on that if needed. Where are you going to be mate? I'll travel to you if i cant clear it. Cars not dropped at all, no other warning lights on, Im taking it the worse that could happen is it drop to the bump stops and 20MPH? Ideally could do with using it from Gravesend to Bluewater this week? What you reckon?
Tel, just did over 1,000miles in mine with EAS inactive fault up, no lights on... was fine...
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I bought an iCarSoft for the reason, on a budget suspension not working and it's been great since!
Unless two height sensors go at the same time, then it hard faults a self levelling fault... Interestingly I cleared it and it came back, then awhile later one of the height sensors starting working and the fault went soft.... fixed itself when I changed both sensors...!!!
As always, thanks so much guys for all your help again!!
Articulation fault will most probably be a height sensor playing up, they usually give you a few weeks notice so expect to have to change one sooner or later... |
Sorry to resurrect an old post.
Tel...
Hey Pete. Thanks fella
Well that's a good toy! Hadn't played with that part of it before!
Looks like front left sensor then, the rest seem OK, they will never be the same, just close....
