Home > Technical (L322) > Inactive suspension and icarsoft |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
Tel, I'm down that way next weekend if it's any help.... Pete
14th Aug 2016 5:30pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
I bought an icarsoft for the same reason - lack of funds and suspension not working. It cleared it without a problem. And I paid £85 on eBay. I figured that if I use it three times rather than going to the local garage I'd be in credit.
14th Aug 2016 5:58pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
I've had the same in an ASDA carpark. Drive off park somewhere turn off an then restart message gone, switch light back. |
14th Aug 2016 7:24pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Pete your a diamond. Thanks so much, may take you up on that if needed. Where are you going to be mate? I'll travel to you if i cant clear it. Cars not dropped at all, no other warning lights on, Im taking it the worse that could happen is it drop to the bump stops and 20MPH? Ideally could do with using it from Gravesend to Bluewater this week? What you reckon?
15th Aug 2016 7:37am |
Tel, just did over 1,000miles in mine with EAS inactive fault up, no lights on... was fine...
15th Aug 2016 9:22am |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
I bought an iCarSoft for the reason, on a budget suspension not working and it's been great since!
15th Aug 2016 1:46pm |
Unless two height sensors go at the same time, then it hard faults a self levelling fault... Interestingly I cleared it and it came back, then awhile later one of the height sensors starting working and the fault went soft.... fixed itself when I changed both sensors...!!!
15th Aug 2016 6:28pm |
As always, thanks so much guys for all your help again!!
16th Aug 2016 7:28pm |
Articulation fault will most probably be a height sensor playing up, they usually give you a few weeks notice so expect to have to change one sooner or later... Pete
16th Aug 2016 10:35pm |
Sorry to resurrect an old post.
30th Sep 2016 1:33pm |
Tel...
30th Sep 2016 2:40pm |
Hey Pete. Thanks fella
30th Sep 2016 3:14pm |
Well that's a good toy! Hadn't played with that part of it before!
30th Sep 2016 3:59pm |
Looks like front left sensor then, the rest seem OK, they will never be the same, just close....
30th Sep 2016 5:02pm |
