Home > Technical (L322) > Inactive suspension and icarsoft
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Is worth a try isn't it!
Cheers fella. Just been 10 mile and hasn't come back on! Always the way.
I'll pick one up tomorrow. Do they have to be calibrated or will I get away with taking battery off before I swap it over?
Cheers Accept, some days your the pigeon, some days your the statue!
Post #407185 30th Sep 2016 6:32pm
You are supposed to calibrate them, I've changed all four on mine and been a bit lazy and not calibrated it and it's not far out...!!!
You don't "have" to disconnect the battery but it is good practice... be careful with the plastic plug on the vehicle loom, they get brittle and the little locking clip can break off, if it does happen a well placed cable tie can hold it on OK... you also need some cable ties to secure the wiring back in place...
Just make sure the arm from it is the right way round, you can flip it over, take a pic of it before you remove it...
You can do it with the car at off road height with the wheel still on but leave a door open and I'd put a axle stand under it just in case... Thumbs Up Thumbs Up Pete
Post #407233 1st Oct 2016 9:50am
Boydonegood
Pete. Your a diamond as always. Thanks fella.
Tel Accept, some days your the pigeon, some days your the statue!
Post #407236 1st Oct 2016 9:58am
