Home > In Car Electronics (L322) > BCM replacement: didn’t go as planned
bebechoon
France
So I finally bit the bullet, bought a new BCM/BCU from Ducky Dan and downloaded the special programming function kindly supplied by those nice people at GAP Diagnostics. (See my previous posts)
BCM/BCU replaced, re-programming function run and (after having to re-synch the keys) everything seems to run normally EXCEPT:
- the front wipers don’t work
- the lower tailgate doesn’t open on the switch.
No faults show for the tailgate, but for the wipers I have the following faults in the Body Processing Module which re-appear straight away after clearing them:
0x49 Wiper enable relay: open circuit
0x4b Wiper speed relay: open circuit
0x30 Wiper switch potentiometer defective.
The only fuse I’ve found for the front wipers is No. 26, which is OK.
Likewise, I’ve checked fuse 86 for the rear tailgate central locking and this is OK also (the upper tailgate opens normally).
I don’t know what else to check Big Cry Has anyone any ideas, pretty please? The wipers in particular need sorting quickly …
Many thanks Bow down It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #406942 29th Sep 2016 10:55am
first thought is to do a battery disconnection.. ... - .- -.
Post #406944 29th Sep 2016 11:04am
bebechoon
France
Thanks for the suggestion, Stan.
I've just done that ... still the same faults and still no wipers, no lower tailgate opening Big Cry
Any ideas, anyone? Bow down It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #406954 29th Sep 2016 12:13pm
fisha
I'd interpret those faults as the bcm not seeing the wiper motor in anyway. I.e. Disconnected cable or similar. Either on the stalk or at the motor.
Are all the wires connected ? V8 or else ...
Post #406956 29th Sep 2016 12:39pm
bebechoon
France
fisha: thanksfor your help! As far as I know all the wires are connected as it all worked properly before I replaced the BCM. I had to undo all the BCM connectors of course and then plug them into the new unit. The plugs seemed to go in correctly ... It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #406958 29th Sep 2016 12:43pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
As it's a new BCU it may well be in transport mode, if it is just take it out, if not put it into transport mode then take it straight out out again, you never know it may work.....
I was told as well that some changes can sometimes take a day or two to take effect, something about the Range Rover bending to your will Thumbs Up
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #406962 29th Sep 2016 12:59pm
bebechoon
France
Thanks, UK Marine, I'll give that a go - why not?!!! Thumbs Up It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #406963 29th Sep 2016 1:03pm
bebechoon
France
Sorry, thanks 'Simon' It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #406964 29th Sep 2016 1:04pm
UK Marine
Fingers crossed
Simon
Post #406966 29th Sep 2016 1:06pm
bebechoon
France
Success!
fisha: you were right on the money!
I have had enormous help from Patrick Meilleur (Patrick’s the best!) at GAP. With his help, the problem was identified as most probably coming from the middle connector on the BCM, C0661, which includes the wiper wiring. I pulled the BCM out again, unplugged it all, inspected the wires and connections, put it all back very carefully and – bingo – I have wipers again!
And my steering is back to being finger-light. Only time will tell if replacing the BCM has also cured the other related problem, the intermittent problem of the rear doors not unlocking with the remote. I am confident, though Thumbs Up
However, I now have some other, niggling problems after the BCM replacement which are most probably to do with the CCF settings. But I am sure those can be sorted, with Patrick’s help.
I really can’t stress enough how good GAP have been. Bow down I know others have praised them before – as have I – but they do seem to go beyond the call of duty. The after-sales support and service is outstanding and should be enough on its own to make the IIDTool the best and first choice of diagnostic tool for our Fatties. It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #407125 30th Sep 2016 12:26pm
bebechoon
France
Just for the sake of completeness, these problems are all now fixed Thumbs Up
It turns out one of the 3 BCM connectors wasn't fully home, despite the clips supposed to hold them firmly in place ...
I really wouldn't have been able to solve this without the continued help and advice from Patrick Meilleur at GAP Diagnostics Bow down whose service has been outstanding and whose patience amazed me.
If you're hesitating over the choice of a diagnostic tool, it's the GAP IIDTool every time for me. A brilliant tool and brilliant after-sales service. It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #407350 2nd Oct 2016 10:35am
Thumbs Up .
Post #407351 2nd Oct 2016 10:39am
UK Marine
I couldn't agree more.
I had the wrong cars software in my BCU and Pat spotted it right away and uploaded the right software. It's been fine ever since.
Their after sales service is second to none and is worth the purchase price of the IIDtool alone.
Simon
Post #407355 2nd Oct 2016 11:23am
fisha
That's great you got it working. V8 or else ...
Post #408259 8th Oct 2016 10:04am
