![]() | Home > Technical (L322) > air suspension |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 ![]() ![]() ![]() |
View live data for air suspension using icarsoft and check the reservoir pressure , should juice up to about 11 bar . If not could be relief valve passing or compressor goosed . First thing I would be checking . Good luck |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Will do that tomorrow.thanks for prompt reply! I checked the airline from the compressor..i take it even if its knackered it will still put out air in some circumstances? Car looks like a dragster with its rear sitting so low😂.. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Sounds like you need one of these.....RQH000130
Will get that checked as well..cheers |
Just checked the data with the icarsoft..says 0.09 bar? |
Going to order a new one from island 4x4 and hopefully that's the problem sorted..appreciate the input my good man..thanks 👍 |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 ![]() ![]() ![]() |
On my discovery 2 when this happened I picked up a length of air hose, a t piece and a schrader valve and assembled an alternative air inlet. Using a tyre compressor on this meant I could get air into the system despite the main compressor not working. Since I hadn't disturbed tthe rest of the system all the sensors did what they should and levelled the car off.
That's genius! May have a wee bash at it this weekend until my new compressor comes...thanks buddy |
Cars locked up in garage..staying away from it until new compressor comes..should have new one mid week anyway.. |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
recently changed a RRS air compressor for a pal of mine, they had done an updated compressor due to the first one being rubbish, if you have an updated version for the FFRR you may need to get it reprogramed by a LR specialist
