Home > Technical (L322) > air suspension |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 |
View live data for air suspension using icarsoft and check the reservoir pressure , should juice up to about 11 bar . If not could be relief valve passing or compressor goosed . First thing I would be checking . Good luck |
28th Sep 2016 9:05pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Will do that tomorrow.thanks for prompt reply! I checked the airline from the compressor..i take it even if its knackered it will still put out air in some circumstances? Car looks like a dragster with its rear sitting so low😂.. |
28th Sep 2016 9:10pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Sounds like you need one of these.....RQH000130
28th Sep 2016 10:42pm |
Will get that checked as well..cheers |
29th Sep 2016 5:17am |
Just checked the data with the icarsoft..says 0.09 bar? |
29th Sep 2016 6:47pm |
Well that's 10.01 bar below what it should be....... I had a worn out pump, did the rebuild thing, and while it improved things, it was very far from fixed...... the rings had worn so much in mine the cylinder had been scored by the piston, and this was knocking the performance for 6..... In the end I had to bite the bullet and buy another pump, I opted for new as there is no way of telling if a used one is scored Yesterday I couldn't spell Engineer... Today I are one!
29th Sep 2016 10:34pm |
Going to order a new one from island 4x4 and hopefully that's the problem sorted..appreciate the input my good man..thanks 👍 |
30th Sep 2016 5:12am |
Strangely enough that is where mine originated from
30th Sep 2016 9:38am |
There's a good business idea! Pity I'm terrible at engineering things.. My cars looking pretty sad just now sitting on the rear bump stops with the front end in normal height..looking forward to getting her back on the road..I've got lots to learn about the full fat but to be honest its really rewarding when I've managed to fix something..cheers |
30th Sep 2016 9:49am |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
On my discovery 2 when this happened I picked up a length of air hose, a t piece and a schrader valve and assembled an alternative air inlet. Using a tyre compressor on this meant I could get air into the system despite the main compressor not working. Since I hadn't disturbed tthe rest of the system all the sensors did what they should and levelled the car off.
30th Sep 2016 12:08pm |
That's genius! May have a wee bash at it this weekend until my new compressor comes...thanks buddy |
30th Sep 2016 12:27pm |
Whoa there Tonto.... the Range Rover system runs at 11 Bar, or put another way 159.541 511 81 PSI, that is way more that than a standard compressor runs at, and a lot more pressure that a standard Schrader is designed to handle as well..... I would wait, as frustrating as it is, compressed air can be a killer and I personally wouldn't play around with such a high pressure system. Yesterday I couldn't spell Engineer... Today I are one!
30th Sep 2016 11:19pm |
Cars locked up in garage..staying away from it until new compressor comes..should have new one mid week anyway.. |
1st Oct 2016 1:13am |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
recently changed a RRS air compressor for a pal of mine, they had done an updated compressor due to the first one being rubbish, if you have an updated version for the FFRR you may need to get it reprogramed by a LR specialist
2nd Oct 2016 8:32pm |
