Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
VC Fan and Aux fan working all good, will give it a shot. |
13th Sep 2016 8:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Two reasons, it's quite a bit cheaper over here than the BMW one and secondly it's quite a bit cheaper over here than the BMW one.... I personally wouldn't use a pattern thermostat either... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
13th Sep 2016 9:13pm |
Why bother, I promise you will never revert to original if you do it, or just fit the 740 one..... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
13th Sep 2016 9:15pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Actually the 740D t-stat is even more here because it needs to be ordered from over there. They never imported the 740d to the US. When I was researching it I was hoping to find it or an equivalent cheaper. Looks like its the mod for me too. |
14th Sep 2016 12:21am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
This is the vemo one i bought which is actually made by behr so i believe is the same as OEM?
14th Sep 2016 5:07pm |
That's an 88 deg one so should be fine, you can't change the stat itself in any of the BMW original stats, that's one appeal of the kit, it's a lot cheaper and then cheaper still if you need to change the stat...
15th Sep 2016 6:39pm |
Ok, thanks, I'll see how it goes, i can always sell one of them to fund the recovery truck when i brick the FF |
15th Sep 2016 7:09pm |
Well I got a spare thermostat from a buddies garage, ripped out the guts, but then I remembered I had an old ELM327 scanner lying around somewhere, so plugged that in to see the coolant temp.
16th Sep 2016 2:43pm |
Take it for a good drive... sitting idling can give false results... Pete
16th Sep 2016 9:17pm |
You're right, I went for a short drive at night, still 34C outside, didnt have the gizmo with me, but scrolled through the secret menu thing where you add the numbers and press left and right knobs etc etc, The car was showing coolant temp as 105C |
16th Sep 2016 10:58pm |
Ok since I had a spare thermostat, I said screw it, had already stripped out the guts, Some one earlier had put the fan on so tight no amount of whacking was opening it, never used the special too on, P38s or L322, A few blows and the fan comes out.
17th Sep 2016 6:33pm |
Pete
17th Sep 2016 7:07pm |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
I've just done this mod go as part of my rebuild. I read somewhere yesterday that you have to Dremel out a notch in the housing for the bleed nipple, I didn't so hope I haven't messed up. Sure I would have noticed though as I was assembling it all.
16th Oct 2016 4:47am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
I've left mine unplugged because when I took the original thermostat apart and took the heating element out I could see the copper of the wires in the remaining housing. My thinking was that when the ECU noticed me putting my foot down it would send signals to the heating element to heat up and as there was no heating element just coolant it might short something.
16th Oct 2016 8:10am |
