Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide
Page 10 of 12 <123 ... 9 101112>
Danwilderspin
Doh didn't realise that - hopefully I can do it through the engine bay not have to take apart AGAIN!
Post #403741 6th Sep 2016 8:18pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
The connector should be down below the coolant expansion tank so it's easy to get to. You will have to just check with a multi meter which of the 2 live wires is the permanent 12v and which is the switched live and then connect that to the ground (brown in the connector)
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #403767 6th Sep 2016 10:20pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Nice to see that there is progress for using alternative high pressure pump.
-Danwilderspin Would you please let me know which pump you used?
-Mattstevenson just for being on safe side when u say
"must connect the switched live from the old LH side washer/wiper connector to the ground (brown in the connector)" you mean pump's connector?????
Post #404049 8th Sep 2016 1:16pm
AKIS
Good day.Any chance for a reply please so start replacement of pump
Post #404578 13th Sep 2016 8:22am
mattstevenson2005
for the headlight washer pump wiring, on the old LH headlight washer connector you connect the black/yellow wire (pin 4) with the brown/black wire (pin 1) i just soldered a wire across them which activates the pump when the headlights are on.
Matt Current
Post #404709 13th Sep 2016 10:53pm
AKIS
So i have to actually bridge pin 1 and 4 of the old lh headlight washer connector.
Many many thanks for your reply
Post #404734 14th Sep 2016 11:11am
Obonano
United States
Good afternoon guys i am planning on doing the conversion to my 2008 but got a question on the bumper washers can I reuse my pump and tank or will it have to be modified and What other things will need to be modified or that could be reused in the 2008 model thanks
Post #428807 22nd Feb 2017 4:59pm
mattstevenson2005
Hi
Ideally you should replace the washer system as the pumps are not powerful enough for the 2010+ bumper jets, however I have heard of someone using a different pump from a BMW in place of the bumper jet pump. They had to modify it to get it to work. With a 2008 you can reuse the crash bar, everything else is as normal and requires changing.
Matt Current
Post #429107 25th Feb 2017 8:14am
Danwilderspin
Hi Matt
Need your help had the mot and was told the lights were cross eyed looking at them it looks that way and I'm out of manual adjustment. The xenons look turned on them like they were going around a corner when they were removed. They are from two different cars and think I got unlucky they are opposite directions.
Anyway you mentioned there was a way to straighten them I believe but you didn't say how so I'm hoping you can tel me now?
Cheers!
Post #430050 5th Mar 2017 9:04am
Danwilderspin
Bump
Post #430901 12th Mar 2017 9:22am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
looking at the 2010 lights over and over again, they look very similar to the 2006 version, out of interest did you offer up the lights to the 2006 grille before doing the rest of the converson ?
Post #430944 12th Mar 2017 3:28pm
^ despite you thinking they look the same, which I disagree with, the grillles and headlights for each respective model don't fit each other. Got - 2017 SDV8 Autobiography in Loire Blue
Post #430956 12th Mar 2017 6:49pm
Danwilderspin
You can see they are turned in when you looke at them and the units are flush to the body work lines. I can see silver paint on the outside side of each projector one a lot more than the other...
Post #430958 12th Mar 2017 6:57pm
Lukie
Dan a few questions
Washer pump for head lights any idea of part numbers ?
Do you recall what needs doing with the parking sensors
I had a 2006 facelift do I need to alter the head light wiring?
Post #453990 13th Oct 2017 10:36pm
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
sorry to be a pain is there anyway to get the guide with all the pictures again I cant see them and if possible would help me plan my install?
Post #468266 12th Feb 2018 11:34am
