Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide
Page 9 of 12 <123 ... 89 101112>
Danwilderspin
Guys I've noticed a problem with this retrofit - the auto levelling headlights don't seem to work... Then looking at the pinout on page one there are no connections for a signal like this just power for main and dip and ground - anyone got round this? Is this legal?
Post #401205 19th Aug 2016 8:11pm
They won't work. Got - 2017 SDV8 Autobiography in Loire Blue
Post #401220 19th Aug 2016 9:10pm
Danwilderspin
Is that an mot failure I thought they had to have headlight washers and auto level?
Post #401229 19th Aug 2016 10:08pm
Danwilderspin
Bit late to worry now it's all done Wink just so I can prepare lol
Post #401230 19th Aug 2016 10:10pm
Never had an MOT tester load the boot with half a ton to check if the self levelling headlights work so don't lose any sleep over it Thumbs Up Pete
Post #401234 19th Aug 2016 10:28pm
You have EAS so as far as an MOT is concerned thats self levelling Thumbs Up
Post #401235 19th Aug 2016 10:31pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi to all.Thanks to this amazing step by step guide i have managed to facelift my td6 but without touching the headlights water pump/water reservoir tank.By reading the new posts found quite interesting the idea of just replacing,if possible,only the headlights pump instead of the all water tank/3 pumps.
After a search bmw x5 2000-2005 headlight high pressure pump seems to be quite similar,according to the attached photo,with RR low pressure pump.
Unfo i compared pumps similarity only thru photos i found in internet so wondering if any chance to have a positive or negative feedback as to whether can be fitted or not
Thanks
Post #401829 24th Aug 2016 4:01pm
Danwilderspin
Hi akis
I'm going to try and mount my washers properly this weekend then I can let you know for sure
Post #401877 24th Aug 2016 8:47pm
AKIS
Excellent.Looking forward for your reply
Best regards
Post #401916 25th Aug 2016 8:50am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Its looking very smart!
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos āžž YouTube.com/RangeRoverOwner
Post #402007 25th Aug 2016 10:17pm
Danwilderspin
Right two things I need to raise - firstly this high pressure water pump...
I got another one through last week as mentioned - swapped it out and it's still not working... Something isn't making sense though - it pumps on the BMWs through the same style high pressure jets, it Infact has a larger bore output so have made the pipe fit. If I drop the pipe below the pump what comes out, and when I squirt it I can hear the pump making the noise ... I'm sure I'm missing something here... If anyone has any ideas great if not it's staying as it is for another 11months as that's when my mot is 😉
Second point - I meant to say earlier those cheap pdc sensors I pointed out on eBay came through stamped valeo (maybe fake?) but for £25 came with the rubber rings and work perfectly if you want to save a few quid there...
I'm now done with face lifting although still toying with the rear bumper... Next is to sort my driver seats out !
Post #403212 3rd Sep 2016 9:50pm
mattstevenson2005
Have you crossed over the 2 wires from the old LH side headlight washer connector wire?
If so the pump will only work when the headlights are on and only every 5 wipes aspect the owners manual
Matt Current
Post #403216 3rd Sep 2016 11:38pm
Danwilderspin
Hi Matt - so I was meant to do something with the wires that went to the headlight wiper unit? I just unplugged and left that - I literally unplugged the old unit plugged new one in and hoped for the best - so what do I need to do? Cheers!
Post #403238 4th Sep 2016 9:20am
Grille needs Black Surround...
Post #403240 4th Sep 2016 9:39am
mattstevenson2005
On the old LH side washer/wiper connector you need to cross the switched live (not the permanent live) to the ground in the connector. The pump will then work when the headlights are on it will spray every 5 wipes.
Matt Current
Post #403723 6th Sep 2016 8:28pm
