Home > Maintenance & Mods (L322) > Which coolant 4.4 petrol M62 |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Pretty sure it's going to be OAT stuff but wanted to check first. Was in europarts yesterday and I asked the chap to look on the system for me and rather than check he told me 100% for sure it's the blue stuff. I said to him I was pretty sure that's for older engines and not to be used in modern alloy engines etc and he just said, no just make sure you flush old stuff out and replace with blue, it will be fine. Based on his recommendations I didn't buy anything, wanted to check I was correct first as I think it's the pink OAT. 2004 RR 4.4 V8 Autobiography |
8th Sep 2016 9:03am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
Hi, for your car it's blue antifreeze.
8th Sep 2016 9:10am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
8th Sep 2016 9:25am |
I agree about the Jag engine but his Range Rover has the M62 BMW engine circa 2003 same as mine, and mine has the blue....
8th Sep 2016 9:31am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
Mine has green. Use a Glysantin G48 Type "A" Ethylene glycol, Anti-Freeze Anti-Boil HYBRID (HOAT - Hybrid Organic Acid Technology) based inhibitor system that is Phosphate, Amine and Nitrite free
The workshop manuals says:
BMW say: http://forum.e46fanatics.com/showthread.php?t=521254 Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
8th Sep 2016 9:56am |
Confused - you will be
8th Sep 2016 9:59am |
Confused? Why? It's dead simple. Ron B. VK2OTC
8th Sep 2016 10:34am |
Hey I'm colour blind so all antifreeze is black and grey to me ______________________________
8th Sep 2016 10:40am |
Confused I am
8th Sep 2016 10:52am |
According to rave as long as the antifreeze is ethylene glycol based containing no methanol but has silicate non phosphate corrosion inhibitors then it will be ok.
8th Sep 2016 11:45am |
Ok that's some useful info I've had, glad I posted now. Think I may use OAT then as its long life but then that is silicate free. So does it need to have silicate or not? 2004 RR 4.4 V8 Autobiography |
8th Sep 2016 1:27pm |
According to rave it must have silicate non phosphate corrosion inhibitors to protect the cooling system.
8th Sep 2016 6:03pm |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 |
Mine has pink/orange stuff in it since I got it. I asked in a motor factors abut it and he told me to use the one that you can now mix with anything. So think I will just top up with water if I have to Declan
8th Sep 2016 8:20pm |
Mann3210 Member Since: 08 May 2016 Location: Perthshire Posts: 56 |
Hi guys, does anyone know where the cheapest/best place is to get a set of 2012 L322 headlamps? Pretty eye watering prices so far! |
9th Sep 2016 8:58am |
