Home > Maintenance & Mods (L322) > Which coolant 4.4 petrol M62
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Pretty sure it's going to be OAT stuff but wanted to check first. Was in europarts yesterday and I asked the chap to look on the system for me and rather than check he told me 100% for sure it's the blue stuff. I said to him I was pretty sure that's for older engines and not to be used in modern alloy engines etc and he just said, no just make sure you flush old stuff out and replace with blue, it will be fine. Based on his recommendations I didn't buy anything, wanted to check I was correct first as I think it's the pink OAT. 2004 RR 4.4 V8 Autobiography
Post #404008 8th Sep 2016 9:03am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, for your car it's blue antifreeze.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #404010 8th Sep 2016 9:10am
Exclamation Exclamation Exclamation Exclamation Exclamation Exclamation Exclamation
OAT orange coolant ONLY in the Jag V8 engine... NOT Blue!!!
Post #404013 8th Sep 2016 9:25am
UK Marine
I agree about the Jag engine but his Range Rover has the M62 BMW engine circa 2003 same as mine, and mine has the blue....
Simon
Post #404015 8th Sep 2016 9:31am
johnboyairey
Do'h. ive got pink in mine (m62) Shocked
however, if you are buying from euro car parts, ask them the price of a 25 litre (might be 20 litre..) as it comes in much cheaper, and handy to have. i think it was about £35 against about £20 for 5 litres. and dont buy the mixed stuff.
just get yourself a jug to pour it at low height, as its too heavy....-for me anyway!
Post #404018 8th Sep 2016 9:55am
p38arover
Australia
Mine has green. Use a Glysantin G48 Type "A" Ethylene glycol, Anti-Freeze Anti-Boil HYBRID (HOAT - Hybrid Organic Acid Technology) based inhibitor system that is Phosphate, Amine and Nitrite free
I'm using (in Aus) Penrite 7 YEAR 450,000 KM Green Coolant http://www.penriteoil.com.au/products.php?...oducts=756
The owner's handbook says:
Quote:
Engine cooling system
Use Texaco AFC coolant, if unavailable, use any ethylene glycol based anti-freeze (containing no
methanol) with only Silicate based non-phosphate corrosion inhibitors. Use one part anti-freeze to
one part water for protection down to -36° C.
The workshop manuals says:
Quote:
Anti-freeze
Use only ethylene glycol based anti-freeze
(containing no methanol) with only Organic Acid
Technology (OAT) corrosion inhibitors, to protect the
cooling system
CAUTION: No other anti-freeze should be used
with anti-freeze containing OAT corrosion
inhibitors.
BMW say: http://forum.e46fanatics.com/showthread.php?t=521254 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #404020 8th Sep 2016 9:56am
UK Marine
Confused - you will be
I know I am. Shocked
Simon
Post #404022 8th Sep 2016 9:59am
p38arover
Australia
Confused? Why? It's dead simple. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #404031 8th Sep 2016 10:34am
UK Marine
Hey I'm colour blind so all antifreeze is black and grey to me Very Happy ______________________________
Simon
Post #404034 8th Sep 2016 10:40am
PaulM
Confused I am Whistle
I thought that if you used the older blue stuff in modern alloy engines it causes corrosion and eats away at the alloy? 2004 RR 4.4 V8 Autobiography
Post #404037 8th Sep 2016 10:52am
UK Marine
According to rave as long as the antifreeze is ethylene glycol based containing no methanol but has silicate non phosphate corrosion inhibitors then it will be ok.
I got the following from the data sheet for Euro car parts triple qx blue antifreeze -
Triple QX Blue Antifreeze Concentrate is an ethylene glycol based engine coolant concentrate formulated meeting BS6580 for use in all engines including those constructed from aluminium alloys. It employs established inhibitor technology and is nitrite, amine and phosphate (NAP) free and includes borate and silicate.
So it looks like the guy from euro car parts was right as long as your not mixing different types.
Simon
Post #404043 8th Sep 2016 11:45am
PaulM
Ok that's some useful info I've had, glad I posted now. Think I may use OAT then as its long life but then that is silicate free. So does it need to have silicate or not? 2004 RR 4.4 V8 Autobiography
Post #404050 8th Sep 2016 1:27pm
UK Marine
According to rave it must have silicate non phosphate corrosion inhibitors to protect the cooling system.
Simon
Post #404080 8th Sep 2016 6:03pm
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Mine has pink/orange stuff in it since I got it. I asked in a motor factors abut it and he told me to use the one that you can now mix with anything. So think I will just top up with water if I have to Whistle Declan
2003 FFRR Vogue 4.4 V8
97 Defender 90 300 TDi
Post #404106 8th Sep 2016 8:20pm
Mann3210
Scotland 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi guys, does anyone know where the cheapest/best place is to get a set of 2012 L322 headlamps? Pretty eye watering prices so far!
Post #404145 9th Sep 2016 8:58am
