Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
A great write-up Pete.
6th Sep 2016 6:39pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
Brilliant Pete, that's taken a lot of the mystery and apprehension away for me.
6th Sep 2016 6:45pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Pete, you simply ROCK!
6th Sep 2016 8:09pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Yes great info Pete,something I will certainly concider |
7th Sep 2016 7:02pm |
Hi Pete,
7th Sep 2016 11:41pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
I reused the O-ring. Regarding not using sealant on the paper gaskets, my kit came pre-assembled. Had it not, I would have used sealant. Mine is weeping very slightly at the paper gaskets. Ron B. VK2OTC
8th Sep 2016 4:41am |
Ok, thank you.
8th Sep 2016 6:40am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
Yep, use the "O" ring again without a gasket at that end, gasket goes between the three leaves and another against the water pump.
8th Sep 2016 7:21am |
Good man, thank you very much ______________________________
8th Sep 2016 7:52am |
Xray charlie Member Since: 22 Jul 2016 Location: Derby Posts: 48 |
Pete,
9th Sep 2016 10:51pm |
Yes. it's a weird sensation.... Pete
9th Sep 2016 11:35pm |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
Good find Pete, Got a question though, even at the coldest we don't even come close to single digit temps in centigrade and in summer high 40s or even 50C, it was 45C-ish todayi, and since you mentioned you ran without a T,stat for months, I'm thinking of getting rid of it althoghter, one less thing to worry about.
13th Sep 2016 5:18pm |
There is the argument that it may effect the flow in the system which "could" cause problems, in reality I don't think it would make much difference, if I were you I'd give it a go, it doesn't take long at all for it to get upto temp in the summer here so I can't see it's an issue there....
13th Sep 2016 5:26pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Hey Pete why this mod vs just using a 740D thermostat? |
13th Sep 2016 7:58pm |
