Home > LPG > Brc help
mattyp
Brc help
I've not had my 2003 4.4 long, today I filled up the tank up with lpg, the engine temp was halfway on the gauge and the car wouldn't switch over to lpg unless I pressed the button myself. Can anyone help?
Post #402813 31st Aug 2016 9:57pm
Had you run out of LPG and the FF switched over to petrol on it's own, if it did then you have to switch back to LPG after filling up, it's not clever enough to know you filled up...!!! Pete
Post #402815 31st Aug 2016 10:02pm
mattyp
The last green led was flashing on the button, I have been out in the car a few times now and it won't switch over
Post #402819 31st Aug 2016 10:20pm
So it won't switch to LPG at all, or you have to press the button every time you drive it..?? Pete
Post #402821 31st Aug 2016 10:32pm
mattyp
It won't switch on its own. I have to press the button my self or it will just run on petrol all the time
Post #402825 31st Aug 2016 10:46pm
There will be something stopping it in the LPG ECU, you need to take it to an LPG specialist, the ECU's are just like all the rest in the car, it will store fault codes.....
Or buy a lead and the software on eBay and do some googling to learn how to play with it.... Thumbs Up Thumbs Up Pete
Post #402832 31st Aug 2016 11:40pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
It sounds like a pressure sensor which isn't activating the system. It could also be a relay so check them first. However, as Haylands said, �40 for a lead and diagnostic cable and you'll be sorted!
Post #402835 1st Sep 2016 12:50am
It's a funny one... if it was a pressure sensor it wouldn't switch over even when asked, if it was a solenoid it wouldn't work at all, a thermistor fault would kill it dead as well... maybe software fault or the switch itself.... Thumbs Up Pete
Post #402837 1st Sep 2016 1:17am
mattyp
what would be the best software to get to read the ecu? The switch in the car does look old i will get another one and see if that sorts it
Post #402840 1st Sep 2016 5:53am
johnboyairey
if you were to disconnect the battery, you would on reconnection, have to (for first time) switch it over to lpg, and then, it should carry on everytime, so, maybe try a battery reset.
nothing to lose, except having to set the time date etc.
Post #402845 1st Sep 2016 7:30am
Do what John says but don't hold your breath...
If it's a BRC system then you need the BRC software and the correct lead to plug your laptop in...
If you want to do it yourself then do some googling and go on the LPG forums to learn how to do it and not make it worse... Thumbs Up
Try Tinleytech for parts, software and lead... Pete
Post #402925 1st Sep 2016 6:24pm
mattyp
Thanks, done this and it works now Very Happy
Post #402929 1st Sep 2016 6:58pm
Superb, we like a cheap fix, had LPG on loads of vehicles and never fixed one that easily....
Maybe worth getting a lead and software if they aren't too much and seeing if it tells you why it happened... Thumbs Up Thumbs Up Pete
Post #402977 1st Sep 2016 10:42pm
