![]() | Home > LPG > Brc help |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Had you run out of LPG and the FF switched over to petrol on it's own, if it did then you have to switch back to LPG after filling up, it's not clever enough to know you filled up...!!! Pete
mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101 ![]() ![]() ![]() |
The last green led was flashing on the button, I have been out in the car a few times now and it won't switch over |
So it won't switch to LPG at all, or you have to press the button every time you drive it..?? Pete
It won't switch on its own. I have to press the button my self or it will just run on petrol all the time |
There will be something stopping it in the LPG ECU, you need to take it to an LPG specialist, the ECU's are just like all the rest in the car, it will store fault codes.....
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
It sounds like a pressure sensor which isn't activating the system. It could also be a relay so check them first. However, as Haylands said, £40 for a lead and diagnostic cable and you'll be sorted! |
It's a funny one... if it was a pressure sensor it wouldn't switch over even when asked, if it was a solenoid it wouldn't work at all, a thermistor fault would kill it dead as well... maybe software fault or the switch itself.... |
what would be the best software to get to read the ecu? The switch in the car does look old i will get another one and see if that sorts it |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you were to disconnect the battery, you would on reconnection, have to (for first time) switch it over to lpg, and then, it should carry on everytime, so, maybe try a battery reset.
Do what John says but don't hold your breath...
Thanks, done this and it works now ![]() |
Superb, we like a cheap fix, had LPG on loads of vehicles and never fixed one that easily....
