![]() | Home > Maintenance & Mods (L322) > "CHECK SIDE LIGHT" |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
I'm no expert with the iid tool, but I think if you turn off the hot / cold monitoring, the bong doesn't sound.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
what greg says, turn off the cold/hot monitoring ... ... - .- -.
davidsmith1307 Member Since: 05 Mar 2015 Location: Hull Posts: 52 ![]() ![]() |
Here you go https://tictail.com/s/deanroper/bong-vase?...m_content= |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Okay. Solved!
Glad your sorted. |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
You'll have to put that one down to UK /= North american english!
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I had a similar issue with mine, it turned out to be the bulb holder terminal had been arcing due to a bad connection and burnt away enough to cause the intermittent bulb out, easy fix but took a while to find it. 2007 TDV8 VSE
D34NO Member Since: 21 Jul 2016 Location: Lincoln Posts: 46 ![]() ![]() ![]() |
I've had the exact same problem it sometimes comes on then goes away, i did the same and checked lights but all worked. my wagon seems to just pick a random fault and go with it for a while then fix itself then pick something else to go wrong, feels like its trying to tell me something either standby for a monumental problem with the wagon or its just laughing at me trying to figure out what the problem is then just as ive got near fixing it, it disappears!!! |
