Home > Maintenance & Mods (L322) > "CHECK SIDE LIGHT"
RR2008HSE
"CHECK SIDE LIGHT"
A number of times recently, I have got a BONG warning to "CHECK SIDE LIGHT".
I put on the IID and it confirmed the error as the left front side light.
So, I just need to replace the bulb, right?
Well...
I DID check the side light and it was working. When I turn on the lights, it's there, along with all the other exterior lights. I've cleared the warning a few times, but it returns.
So. I'm getting a warning for something that's working. Any ideas?
Is it worth getting a new side light? I can't imagin they're very much $.
Help and explanation would be much appreciated.
PS Anyone know the part number for the side light? Thx Bow down
Post #402507 30th Aug 2016 6:14am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I'm no expert with the iid tool, but I think if you turn off the hot / cold monitoring, the bong doesn't sound.
someone who has a better knowledge than me may help. Thumbs Up
I have to give credit to lr, as the bong of doom always seems to work, it's the one thing that never breaks down.
I've never seen a second hand or new bong for sale. Laughing Laughing Laughing
Post #402513 30th Aug 2016 6:29am
what greg says, turn off the cold/hot monitoring ... ... - .- -.
Post #402520 30th Aug 2016 7:32am
davidsmith1307
Here you go
https://tictail.com/s/deanroper/bong-vase?...m_content=
Post #402525 30th Aug 2016 8:17am
gregdav
Post #402670 30th Aug 2016 8:10pm
RR2008HSE
Okay. Solved!
I couldn't figure out why I was getting an error when the bulb was good.
So, the red arrow shows the "side light". It's the side light because it's on the side of the car!
The green arrow shows what I call the "running lights" (US term: "parking lights"). That one turn out to be out. Evil or Very Mad
Sorted.
Embarassed
Post #402705 31st Aug 2016 12:30am
gregdav
Glad your sorted. Thumbs Up
Post #402710 31st Aug 2016 5:08am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
You'll have to put that one down to UK /= North american english!
We use sidelight for the small lights that mark the sides of the car from the front - it's a hangover from prewar years where the main lights were normally inboard of the wings. The yellow lights (your red arrow) are normally called side markers by us (we don't have them on UK spec cars). A small but important difference Smile
Post #402715 31st Aug 2016 6:50am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I had a similar issue with mine, it turned out to be the bulb holder terminal had been arcing due to a bad connection and burnt away enough to cause the intermittent bulb out, easy fix but took a while to find it. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #402717 31st Aug 2016 7:31am
D34NO
United Kingdom 2003 Range Rover HSE Td6 Monte Carlo Blue
I've had the exact same problem it sometimes comes on then goes away, i did the same and checked lights but all worked. my wagon seems to just pick a random fault and go with it for a while then fix itself then pick something else to go wrong, feels like its trying to tell me something either standby for a monumental problem with the wagon or its just laughing at me trying to figure out what the problem is then just as ive got near fixing it, it disappears!!! Evil or Very Mad
Post #402725 31st Aug 2016 9:12am
