Home > Maintenance & Mods (L322) > JET WASHING your FFRR - READ THIS *
Page 1 of 3 123>
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
To all concerned
Washing your FFRR is a good way to look after her.
I have been thinking of this idea for ages and finally got around to it today
Have you ever thought about Water rates that you get charged for ? - Rain water is FREE !!!
I got a 400 liter Heavy duty drum + Water Butt Tap with Hozelock Connector and thought can I connect the heavy duty Karcher pressure washer ( High pressure washer HD 13/18-4 SX Plus ) to it and hell it works brilliantly.
Out of interest I washed both FFRR and looking at the butt used about 2 buckets of water per FF.
So if you pay water rates this is another way to get FREE "CHLORINE" / FREE WATER totally free
The only thing you have to do is wait about a minute for the water to flow to the jet wash - press trigger to get water in the system then power on - as easy as that
one thing I will do tomorrow is connect a small filter inline iwth the hose - in case any C**P come sof the bard roof - but it worked very well !
I hope this post is again of some use to anyone who reads it
Best wishes team Thumbs Up
Post #402152 26th Aug 2016 8:51pm
mzplcg
Been using rain water to wash cars for years. Nice and soft, doesn't leave white spots all over the car.
Post #402153 26th Aug 2016 8:53pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Got wo underground 17th century watertanks 8000 liter each, could start a carwash... Mr. Green
But it's true it is great to wash your cars with rain water. Much softer, no stripes etc.
Post #402154 26th Aug 2016 9:04pm
Living in Scotland "soft" water is available on tap Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #402157 26th Aug 2016 9:37pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
This is going to sound weird.......
If it happens to rain on a clean, newly washed car in this area, the rain spots leave a sand-like ring so the after rain, the car is dirty!
If it happens to shower on and off for a few days, the car ends up taking on a baked on sandy/dusty appearance......
Which is why I used a DI Vessel and not rainwater.......that and the fact that our tap water has a TDS reading of between 312 and 324 (very hard water).
Post #402159 26th Aug 2016 9:49pm
p38arover
Australia
We have a 9,000 litre rainwater tank behind the house but the Karcher pressure washer doesn't seem to like the low pressure from the tank - so I've given up trying to use it. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #402163 26th Aug 2016 10:27pm
mzplcg
And from the skies, on a fairly constant basis Thumbs Up Laughing Laughing
Post #402185 27th Aug 2016 8:09am
p38arover
Australia
But not here! Twisted Evil Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #402193 27th Aug 2016 9:41am
EmiratesA380
This could be a very simple case - have you bleed the air from the hose ( simply running water to the Karcher before you turn it on ) - ours is a high output units.
I can only think - just ensure the pipe is lower than the tap output ( the tank we have is mounted about 3 feet off the ground )
with the amount of water in the tank - there's quite of bit of pressure with the water volume pushing down ).
It will work - just re check everything - good luck
Post #402194 27th Aug 2016 9:57am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
hi Emirates
I use this method and it works great stops all the nasty white spots
what in-line filter are you thinking of using - I think I should fit one but not sure which type to use
found this one on fleabay item number:221412544899 do you think it would do the job ?
Phil various other LR's this one is still the best
Post #402197 27th Aug 2016 10:44am
rar110
I rarely use a hose to clean my car these days. I clean my cars with chemical guys quick detailer and two microfibre towels. It takes me 15-20 min including wheels. ______________________________
Post #402200 27th Aug 2016 11:25am
Andy K
United Kingdom 2005 Range Rover HSE Supercharged Rimini Red
Re: JET WASHING your FFRR - READ THIS *
If you really think you have saved 2 buckets I don't think it has saved you much money. Must be talking less than �1.
You still have to pay drainage fee's.
If you want to save money, get a lighter car! Rolling with laughter
But seriously, I would fit the filter. Don't want to knacker your pressure washer all for saving a few pence.
Post #402205 27th Aug 2016 11:48am
p38arover
Australia
I'll try it.
The outlet on our tank is at ground level but a full tank has a head of nearly 2.4 metres (8 ft). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #402211 27th Aug 2016 12:27pm
EmiratesA380
philbathurst wrote:
hi Emirates
Phil
Hi philbathurst
I thought BIG and put in a massive Tea Strainer as this - looks impressive and so far works very well
I ve placed it in the top near to the inlet inside the tank about 2 inches from the max position, secured in place by alloy sleeves so it cant move ( but you can lift it out ) - watched it in action with very heavy rain and water only went half way up the strainer - so it kept up with the flow.
Its easy to lift out and clean any debris if required - didn't want a little filter as it would get blocked ( rangie is big so is the filter )
again hope this helps with ideas you may have.
best wishes
Post #402213 27th Aug 2016 12:56pm
EmiratesA380
Sometimes AndyK - you have to think outside the box
There are some less fortunate than us and money is tight - so on this web site we all try to help each other - thats the whole purpose - Save money and do things over selves !
and one other thing - the jet wash is around �1000 - and having crap in the lines will knacker it in some form or another - Period.
That was all
Post #402216 27th Aug 2016 1:01pm
Page 1 of 3 123>
