Home > Technical (L322) > coolant leaks and cylindre head
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I agree he should try that. For me the slightest coolant leak smell jumps out. Perhaps it's the higher temp the 4.4 runs at and maybe the td6 runs cool enough to miss it.
Post #402024 26th Aug 2016 3:01am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Mine had a hairline crack in the expansion tank; took me a while to spot it as the leaking coolant evaporated from the tank surface.
Post #402026 26th Aug 2016 6:40am
pepa80
Spain 2005 Range Rover Vogue Td6 Giverny Green
Hi.
There is something like rest of evaporated coolant with white-rusty color which seems to come from a leak in the head gasket at the height of the cylinder 6.
Also, you can appreciate there is a losen bolt of the exhausted manifold. I suppose it has nothing to do with this puzzle.
Thanks
Post #402134 26th Aug 2016 6:30pm
If that exhaust is blowing then you will get discolouration like that from the combustion gases mixing with water from the road etc...
Also a leak like that would show up with a pressure test of the system.... Pete
Post #402139 26th Aug 2016 6:58pm
doclees
It is a starting point to check. Nothing looks wet and traceable. Try running the car around for 20 min or so. Shut off and see if any coolant is there. Check every 10 min as it cools.
Post #402140 26th Aug 2016 7:05pm
pepa80
Hi.
Well, finally, i have a diagnosis of that coolant leak. Unfortunately, the cylinder head is cracked.
To tell you the truth, I'm a bit dissapointed with BMW engines. I thought they were more reliable. Maybe former owner overheated the engine or, as I have been said, the cylinder head might have been cracked after a neglected repair of the turbo.
In a fex days i will have Rangie back, so we will see how it is working.
Anyway, thanks everybody.
Pepa80
Post #405119 17th Sep 2016 11:24am
doclees
Oh so sad. Big Cry
Post #405204 18th Sep 2016 5:41am
