Home > Technical (L322) > coolant leaks and cylindre head |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
I agree he should try that. For me the slightest coolant leak smell jumps out. Perhaps it's the higher temp the 4.4 runs at and maybe the td6 runs cool enough to miss it. |
26th Aug 2016 2:01am |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
Mine had a hairline crack in the expansion tank; took me a while to spot it as the leaking coolant evaporated from the tank surface. |
26th Aug 2016 5:40am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
If that exhaust is blowing then you will get discolouration like that from the combustion gases mixing with water from the road etc...
26th Aug 2016 5:58pm |
It is a starting point to check. Nothing looks wet and traceable. Try running the car around for 20 min or so. Shut off and see if any coolant is there. Check every 10 min as it cools. |
26th Aug 2016 6:05pm |
pepa80 Member Since: 19 Aug 2015 Location: Madrid Posts: 17 |
Hi.
17th Sep 2016 10:24am |
Oh so sad. |
18th Sep 2016 4:41am |
