Home > Maintenance & Mods (L322) > puddle lights in wing mirrors of vogue on a 54 plate
Page 2 of 4 <1234>
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Also, on a related note.....I remember fitting LEDs to the interior of a Lexus some years ago. Because the original lights used to "fade" out (like turning a dimmer down) the LEDs didn't like this at all. They were far more suited to a binary on / off application. I'm sure LED light technology has moved on since but it's worth bearing in mind as far as I can remember the FF puddle lights do the fading thing.
Just one to bear in mind....... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #243456 18th Feb 2014 8:25pm
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi guys
yes that is quick and clever thinking. but i did think about that and i have turned the offending bulb 180 and tried that but it still does the same thing Question Question Question Question i have also contacted the chief at powerfuluk.com where i bought the bulbs and the MD has just emailed me and said that this is the 2nd complaint they have had with these bulbs and they have taken the matter up with OSRAM UK, and is going to get back to me hopefully tomorrow. they do look very cool so hopefully the answer will be found.
if not i will have a blue door and a white door Rolling Eyes Rolling Eyes Rolling Eyes all i need now is a red one and i have the french flag colours where i live Rolling with laughter Rolling with laughter < well i think thats the colours anyway Embarassed Embarassed
thanks for your replies but any other idea's will be gratefully received as allways Bow down Bow down Bow down
Post #243472 18th Feb 2014 8:33pm
BOBCUSSEN
hi skot
actually im sure these leds also fade unless i have imagined it but i will pop out and check and let everyone know
regards
bob
Post #243476 18th Feb 2014 8:37pm
SKOT
Can you swap them door to door? That will definitely tell you if the bulb is at fault. 2006 4.2 SC
Post #243477 18th Feb 2014 8:37pm
BOBCUSSEN
hi skot, firstly i can confirm that they do fade out when they or should i say it goes out. i have changed the one around into the other door and it works, ie the paessenger side bulb which noes not stay on, works fine when i put it in the drivers side. i have not tried the drivers side one in the passenger side as i could not see the point. as both white original bulbs work fine in either side Question
bob
Post #243486 18th Feb 2014 8:50pm
BOBCUSSEN
system works
HI EVERYONE
just to add to my last post regarding the failure of the blue led bulbs. i think it it is a bulb polarity problem as suggested by stan.
when both white bulbs are installed the system works as required.
if i install one white ( original bulbs ) and one blue they both work fine as required in either side
but when both blues are installed then they will not come on.
i have rotated each bulb 180 in each side and makes no difference.
i have passed these finding onto the suppliers and they are taking it up with OSRAM, who make the bulbs.
so if you have any other possible causes i would be very interested in listening.
kind regards to you all
bob
Post #243880 20th Feb 2014 6:26pm
p38arover
Australia
Joe90 wrote:
Hey Bob
See my photo howto on the wiki
http://www.fullfatrr.com/gallery/thumbnails.php?album=341
Thanks Joe. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #401272 20th Aug 2016 7:03am
i sussed this led bulb problem out and it seems you need a resister or one of the old incandescent bulbs wired in, it all works then ... - .- -.
Post #401286 20th Aug 2016 8:42am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Re: system works
Unnecessary quote removed
mine does the same
have not got round to looking for a fix
looking forward to a easy solution
Post #401312 20th Aug 2016 11:12am
easy solution fix above... Thumbs Up ... - .- -.
Post #401318 20th Aug 2016 11:35am
ironhorse
ill give it a go then
Post #401431 21st Aug 2016 9:37am
it does work and easy to do..you prise the two contacts from the ols bulb and solder in line with the new led..tape it up and tuck inside the mirror housing..only one side needs to be done.. ... - .- -.
Post #401445 21st Aug 2016 11:03am
BOBCUSSEN
HI stan
thanks for the info, cant get me head around what your suggesting but im sure it will come; Rolling Eyes perhaps i will pass your answer to simon at powerfull.co.uk and see if they can have some made up
bob
Post #401494 21st Aug 2016 6:40pm
p38arover
Australia
This is effectively putting a low resistance in series with the LED. As the LED draws very little current, the old globe probably won't light up, and its resistance won't change a lot as the current flows through it but it will slightly reduce the voltage on the LED.
Generally, when people have LED issues (and it's not a polarity issue), they put a low value resistor in parallel with the LED, not in series, to increase the current flow though the sensing circuit. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #401516 21st Aug 2016 11:03pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I thought that was why they introduced " Canbus" led bulbs and presumed they had a resistor built in. Am I wrong?
http://www.ebay.com.au/itm/4-x-Canbus-T10-...Swrx5UXCqZ 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #401552 22nd Aug 2016 12:38pm
Page 2 of 4 <1234>
