![]() | Home > Maintenance & Mods (L322) > puddle lights in wing mirrors of vogue on a 54 plate |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Out of interest, what value resistor is suggested? John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
i think those little 501 bulbs are only about 2/4 ohm John , so not to big.. ... - .- -.
Thanks. Stan. |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI FOLKS
parallel Bob, just to load the wiring with resistance..you only need one side done...luckily the contacts on the old bulb bend out easily for connecting a wire or soldering .. ... - .- -.
hi stan
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Don't know what the problem is.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Either do I ..I've tried 3 different brands of led so it's not the bulbs. The one that does work has made a big diffrence. A lot more illumination from it compared to the old bulb..
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Wow these white are bright |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I sorted this problem on my '06 by unfolding the wires on the old build and pushing the wires of the old bulb down inside the holder where the wiring goes into the holder, few drops of glue to hold them in place and then just refitted the holder into the mirror.
^ good idea.. |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Like the idea hamlet Regards
so by doing that with the old bulb, does that do the same thing as soldering a resistor across the wires ?
