Home > Technical (L322) > Rear loadspace aux socket not permanently live ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
Been there, done that....got well confused....
17th Aug 2016 8:37pm |
Yep, the manual is wrong. However, you have a massive 100 amp feed in that cubby which can be used to power the socket, via an appropriate fuse of course. |
17th Aug 2016 8:40pm |
And welcome to the forum....
17th Aug 2016 8:42pm |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 99 |
Cheers for that , was only intending using it for phone and ecig charging so may look at a minor rewire . |
17th Aug 2016 9:50pm |
Not sure if the USB is powered or if that iPod thing could be used..... 2011 Range Rover Vogue SE 4.4 TDV8
17th Aug 2016 10:10pm |
USB is powered as are all the other multitude of aux sockets but all turn off after a few mins , If I'm away for weekend on pushbike I tend to want to charge phone up on a night (use viewranger on it for mapping ) and a 4.4 TDV8 battery charger is a bit excessive !, I might just hard wire (via a fuse ) another aux socket in somewhere that's easier to access as the boot socket is covered by over the top boot liner (we have 2 collies ). |
19th Aug 2016 8:55pm |
