Home > Maintenance & Mods (L322) > Gearbox Issues
Page 3 of 4 <1234>
Danwilderspin
Also Phil, a couple of points - if there is still a problem am I causing any serious damage driving like this or will the crack eventually just get bigger and bigger?
Also on another forum I saw you carried a few used ones you sell is that the case still?
Post #396878 20th Jul 2016 5:07pm
RRPhil
The transmission is pretty good at looking after itself – in fact some would say the control system is actually too sensitive as it drops the transmission into failsafe at the merest hint of unscheduled clutch slip. Eventually the upper valve block crack gets worse until the edge breaks off.
(The above two photos aren’t mine by the way, I nicked them off a BMW forum)
And, yes, I have loads of used ones lying around
though I’m not convinced that this is actually your issue now. Like I said, it’s pretty unusual on the L322 and was much more common on earlier BMWs and Jaguars before the pressure spike problem was fixed with the revised main pressure valve (which all our Range Rovers have got). Having said that it would only ‘cost’ you a sump gasket and a bit of fresh fluid to check.
Phil
Post #396885 20th Jul 2016 6:26pm
Danwilderspin
Ok thanks Phil - any light you can shed on how I should expect to slow down from speed quickly? Should it feel like engine breaking - not bucking like it was before?
Also I meant to say during this whole debacle from the beginning and even when it was only going into gears 1-3 when it was hit prior to oil cooler and rad, I had NO faults either on the check control nor in the gearbox fault memories - not sure if that's relevant p
Post #396919 20th Jul 2016 9:29pm
Danwilderspin
Also would you think a litre and a half low on oil could be enough for my issues?
Post #396920 20th Jul 2016 9:33pm
RRPhil
When you decelerate in ‘automatic mode’ the torque converter will be open (LUC off) and behaving as an inefficient fluid coupling so you would expect little engine braking. You will notice that the engine revs stay relatively low throughout the deceleration process even though the transmission is downsequencing. By engaging manual mode you can lock up the torque converter and also keep the engine revs higher by selecting a lower gear so it’s then possible to get an amount of engine braking – but it’s never very much in the higher gears.
Phil
Post #396958 21st Jul 2016 9:20am
Danwilderspin
thanks phil - will have a play in the next few days and see how we get on!
Post #396964 21st Jul 2016 10:28am
Danwilderspin
Guys back on this - Reading haylands old post I would say it sounds a similar issue now as the gear changes seem to always go from 1-5 now - it just bangs a bit into second when hot and seems like fairly severe engine braking - he said it was a blocked solenoid that cleared itself?
Also what should the rpm be at idle it sits about 400 , and in drive normal about 700 when crawling?
Since yesterday in drive it crawls at about 1000rpm and idles about 700 - which is right and do I have an issue?
Post #399119 4th Aug 2016 7:36am
Danwilderspin
PaulTyrer - when are you about Cambridge way? would be good for a second opinion - I'm here today and will be a couple of days next week also...
Thanks
Post #400701 16th Aug 2016 12:54pm
Danwilderspin
Right - dragging this back up - as I had done everything but the oil change I decided that was the last piece to the puzzle before I need to consider big things - ended up buying the genuine Mobil oil genuine lr gasket and filter.
As I know the cherry stuff is in it (there was a bottle that came with it I used to top it up) I had planned to drain the sump and refills with correct oil then next weekend do the same again and do the filet and gasket that way I should have around 80% correct oil - anyway did today drain - fine - went to pump with my electric oil pump the stuff in and it struggled - it is noticeably thicker than the cherry stuff and than the average engine oil - is this the norm? Got about 4-5 litres in (while running at temp) and drove her for 50 miles and so far... seems a different gearbox ... and that's with only half the change done - will see how I get on this week then Change the rest
Post #406217 24th Sep 2016 8:23pm
RRPhil
Automatic transmission fluid, whether it’s Dexron-type or LifeGuard Fluid 5-type, has a kinematic viscosity of around 38 mm2/s at 40°C. For engine oil it’s much higher (around 90 mm2/s at 40°C for 5W 40 or 10W 40), so your Mobil ATF LT71141 fluid certainly shouldn’t be ‘noticeably thicker’ than Dexron or engine oil. You can see how ‘thin’ it appears here :
Phil
Post #406318 25th Sep 2016 1:21pm
Danwilderspin
Hmmm well it certainly is different my example may be a bit out but this is what I bought
https://www.ebay.co.uk/itm/141496578109
And this is what the previous owner filled with judging by the half bottle in the boot
http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000769
Would you expect a big difference?
Post #406360 25th Sep 2016 5:42pm
Danwilderspin
Ok sorry to keep pulling this back to the top but done a 600 mile round trip down south and we went over a fair few hills. A couple of time I had my foot at mid thottle revs would be nice at say 2.5k and the it would jump gears and revs would go to 5.5k then it would go back to the 2.5 k all on the space of about 4 seconds - foot did not change - is that normal behaviour?
Post #407199 30th Sep 2016 9:55pm
Sorry, haven't been keeping up with this thread... you are going through the same scenario I did, I managed to get many thousands of miles out of my dying box before I gave in and decided to rebuild it, then found out it had been attacked inside by a hammer wielding maniac resulting in a replacement box that had been recently rebuilt, Fatty has been a different vehicle since...
If I were you I'd save a few pennies and get a rebuilt box from Phil when yours really starts to die, drive gently and ease off as it is just about to change gear and you can "make" the box work quite well, but don't think your box is OK with just minor issues, it will be struggling inside to do what you ask and only getting worse...
Sorry to be all doom and gloom, just blame the idiot who put the wrong fluid in...
That last sentence will probably start a big argument about other oil being fine.... personal experience tends to disbelieve this.... Thumbs Up Thumbs Up Pete
Post #407231 1st Oct 2016 9:38am
Danwilderspin
So haylands is it worth me continuing my oil change I've done half already? Will it make a difference or shall I leave the mixed mess until it dies? It's never had any gearbox faults or protection warning since I had it - the plane was to drop the oil out again and look at the filter and the meccatronic thing that cracks at the Same time this weekend or next depending on wEather ? How many miles did you get out of yours before it packed in? Also was it a catastrophic failure or were you still able to drive about? The original gearbox faults of stuck in hers is well and truly gone now...
What will have been dying ? The tc? If the rest of the box was fine wouldn't it be cheaper to just change that
Post #407249 1st Oct 2016 12:43pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
I would carry on with changing the filter.
This way you can see what metallic rubbish the magnets have picked up in the pan, this will give a pretty good indication of wear.
Seems odd that the trans had a rebuild 25k ago and input shaft seal is leaking already?
The increased revs you report on a hill climb at half throttle, sound normal to me, thats just the trans maintaining road speed, these are pretty gutless engines for a V8 due to their small displacement.
The engine will hunt quite a lot in hilly terrain, especially in cruise control.
Post #407321 1st Oct 2016 9:52pm
Page 3 of 4 <1234>
