Home > Technical (L322) > BUSHES BAR TWIST
DoubleRL322
United States 2003 Range Rover HSE 4.4 V8 Zambezi Silver
I replaced the rear sway bar links and tie rods/stabilizer links and what a difference! The old ones were completely shot. The roll I was experiencing has been cut down significantly. Very Happy
I have new Bilstein struts ready to go on the rear (These ones: http://www.island-4x4.co.uk/rear-shock-abs...28025.html )
I am going to follow Cam's advice and do new rear air springs as well.
Since I already have the Bilstein struts, do I have to get the Land Rover air springs? Or can I get Arnott?
Which ones are better?
Post #400609 15th Aug 2016 3:07pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I replaced my rear dampers for OE Bilsteins after renewing the front struts to keep it all the same age/condition. After 10+ years and 100k miles they needed swapping and the new ones were a lot better.
I've not touched the rear springs as my are still OK, they might need replacing in the next few years but I thought that 5 years ago!
As to what to replace them with, well you can put what you like on there but the ones I have are the originals, they've lasted 14 years. Do you replace them with an unknown quantity or stick with OEM that in theory is going to last another 14 years?
I know where my money would go.
Post #400618 15th Aug 2016 3:59pm
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
miggit wrote:
Try these they are better value Thumbs Up
https://www.famousfour.co.uk/new_parts/ff_part?part=16123
http://www.island-4x4.co.uk/bush-front-rol...-8020.html
Hey, These bushes are meant for the armoured version of the L322.. or so I've been told. They are compatible with the normal consumer L322?? I.e 31mm dia bar?
Thanx Matt Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
Post #573705 22nd Nov 2020 3:04am
