Home > Technical (L322) > BUSHES BAR TWIST |
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 |
I replaced the rear sway bar links and tie rods/stabilizer links and what a difference! The old ones were completely shot. The roll I was experiencing has been cut down significantly.
15th Aug 2016 2:07pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
I replaced my rear dampers for OE Bilsteins after renewing the front struts to keep it all the same age/condition. After 10+ years and 100k miles they needed swapping and the new ones were a lot better.
15th Aug 2016 2:59pm |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
Hey, These bushes are meant for the armoured version of the L322.. or so I've been told. They are compatible with the normal consumer L322?? I.e 31mm dia bar? Thanx Matt Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life. 1986 RRC Highline with offroad mods. Arctic Silver 2001 P38 HSE. Ardeness Green. 1995 RRC soft dash (beautiful car) Green. 2005 L322 HSE V8. - Current, most awesome car yet. And most expensive. |
22nd Nov 2020 2:04am |
