![]() | Home > Technical (L322) > BUSHES BAR TWIST |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/2x-BEARING-STORA...SwnDxUdEzz
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi, I think that you are looking for ANTI ROLL BAR bushes |
Try these they are better value |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8525 ![]() ![]() ![]() |
Actually JLR do sell them now without the bar, I have a pair in the garage... Ask Dan, not too much money and they are polyurethane...!!!
I'll answer your question on the other post so as not to off topic this one... |
Thanks for the information!!! |
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 ![]() ![]() ![]() |
Hi Guys,
You have to remember it's 2 1/2 tons on long travel suspension, they do roll,
Thanks Pete. Yes, that is very true and I have only had it for about two months and have never driven one prior to this. I am in the process of overhauling the suspension as I would like it to feel as if it just drove off the lot. The truck has 135K miles. The front air shocks/struts were changed by the dealer 8 years ago at 90K miles. The rear air shocks & struts were never changed.
Do the rest first and see what you think... see if you can drive a few others to compare...
I would definitely change the rear shocks & air springs straight away. IMHO that will make quite some difference to the drive sir |
Thanks Pete |
Here are some close ups (this was before I did the upper and lower bushings):
