Home > General > Suspension Fault |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 |
Sorry, should have posted under "Technical" section, don't think I can move it now...... |
26th Jun 2010 1:47pm |
Get yourself one of these EAS Reset tools. It does more than reset, it reads the stored fault codes and gives you a description of the fault. It saves you chasing your tail a lot and is about the cost of 1hr's labour at Land Rover.
26th Jun 2010 2:52pm |
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 |
there is a modified exhaust filter for compressor (small brass looking tapered plug screwed in on the end)
26th Jun 2010 2:55pm |
Thanks for that dan_uk_1984, but as great as that tool looks to be, I don't believe it will work on my 2007 MY car, such a pity.
26th Jun 2010 3:24pm |
Cheers, Have you had similar issues to me? and did this exhaust filter mod help you?
26th Jun 2010 3:27pm |
i have sorted a few with this fault
27th Jun 2010 6:11pm |
Thanks lrdraft, that was exactly what my problem turned out to be, after a new modified exhaust valve on compressor, the car is now up and down like a hores draws
29th Nov 2010 4:48pm |
i knew that would cure it you would not beleive how much people renew expensive parts unnessasary
5th Dec 2010 7:38pm |
