![]() | Home > Maintenance & Mods (L322) > diagnosing front parking sensors |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
ok i'm a bit confused on this. my iidtool says no issues. i did the key on press sensor button. my rears give warning tone. the front right outer clicks and the others are silent. no tone when standing in front of any front sensor. anyone know what this means and what to test next? thanks. |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
If the rear is giving a warning tone, as far as I know it would be a problem with the rears.
Maybe I should have said the rears work normal. I guess I will just try the good front one in the other positions and see if I still get click. |
Ok I got around to using the iidtool live values to test sensors. My live values show that the sensors are working yet it still doesn't give tone in the cab. What next? Are there 2 different tone speakers where one could be bad? Live values for the rear sensors are the same as the front yet the rears work fine. |
OK system descriptions section of RAVE showed 2 Sounders. One is either part of or attached to the instrument cluster. Anyone know where it is at? |
Thanks Andy K. I will check again on the software enabled. I didn't notice that option but I was looking for testing. Is the front sounder replaceable or does it require a new instrument cluster. That would be a stupid design. |
iidtool says front parking sensors are on. |
Update. I replaced the front parking aid speaker. I now have door and lights on chimes but still no front parking sensor sounds. Just to recap-
Problem solved.
