Home > Off Topic - Other Cars > Citroën berlingo |
Have you tried the other locks as there should be one on the back door or passenger door unless its base spec?
2nd Aug 2016 9:29am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi kp, thanks for your reply, I've managed to open the driver's door, and all the other doors have opened as well, it took a few attempts, but as you say, a little up and down pressure did the trick.
2nd Aug 2016 3:54pm |
I'd see how much a new lock is from Citroen as they aren't too hard to do either but if the side and rear have the armour lock plates maybe get an armour lock.
2nd Aug 2016 4:05pm |
Thanks kp, yes it is the 1.6 hdi, 75ps I believe.
2nd Aug 2016 5:37pm |
No probs fella FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
3rd Aug 2016 2:43pm |
Thought I would update this, repaired fob to car, I think his battery in the fob died, then lost the rolling code, downloaded manuel, and it's as easy as key in ignition, turn on, press lock button once, turn off remove key, and that's it, fobs working like a good one.
9th Aug 2016 2:51pm |
Happy to help Greg FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
9th Aug 2016 3:37pm |
Cheers. |
9th Aug 2016 6:40pm |
