Home > Maintenance & Mods (L405) > missing bits. tool kit?
bear100
Hi all,
Just noticed i am missing my locking wheel nut from my new ranger over,
under the spare wheel in the foam section is just a wheel brace and further back under the seat is the jack
Should there be anything else? the foam section has lots of empty sections, tool kit etc?
Thumbs Up Thumbs Up 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #398631 1st Aug 2016 10:04am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
if you have a full size spare wheel there should be a wheel lifting strap kit - this was missing on my new one - took a couple of calls to the dealer to convince him it should be there, they eventually supplied it FOC various other LR's this one is still the best
Post #398640 1st Aug 2016 11:09am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I bought the wheel lifting strap kit from Dan @ Duckworths. It is only a few pounds and easy to instal.
Post #398666 1st Aug 2016 1:52pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Sorry the boot needed hoovering out - just got the car.
Post #398706 1st Aug 2016 5:02pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Chocks and wheel brace are under the spare wheel.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #398740 1st Aug 2016 8:28pm
bear100
Ahh thanks guys, will have a chat to the dealer tomorrow!
Thanks for the pictures found the locking wheel nut now! 2010 defender utility
1994 discovery 1
1975 bobtail (gone)
Post #398744 1st Aug 2016 8:54pm
Mariana Black
Hi
After reading the listings and posting the picture I decided to clean the boot out.
If you have ever tried removing the spare wheel you would not do it without the lifter. If you dont have one get one. I am reasonable strong but this is very difficult and heavy.
Hopefully you guys will never need to try.
Cheers
3.0L Autobiography 14.5M
21" wheels
Post #399210 4th Aug 2016 6:25pm
CUE99T
quick one....the lifter....is it a cable with a red hook on it? I have that but don't know if thats all the lifter is?
Any help appreciated.
Missing the first aid kit which is no biggie but will ask my dealer for a replacement. all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #421185 4th Jan 2017 9:00pm
Giantlandyman
I don't know if it's the same on the 405 but the 322 has two straps that attach in the wheel well wall near the back seat, go under the wheel and a long black plastic 'bracket' that slots into the lower tailgate lock.
Unravel the black bracket, put in the lower tailgate and open...hay, presto! The wheel is lifted upwards on slightly forwards of the wheel well.
Post #421196 4th Jan 2017 10:12pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
its different on the L405. One leg of the strap has a hook which goes on to the top of the rear tailgate opening. then a lifting plate on the other leg fits in the centre of the wheel and the remaining strap is pulled to lift the wheel from the well like you were using a block and tackle. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #421217 5th Jan 2017 7:12am
caymanblack
The first aid kit is a option.
Post #421284 5th Jan 2017 4:45pm
Welshhope
Wales
At a reasonable £35!
Post #421343 5th Jan 2017 9:28pm
