Home > General > Do you drop the suspension when parked overnight?
Page 5 of 5 <12345
How do you know it led to it failing....??? It's impossible to say, the bags fail when they get to the end of their life, they are a replacement item like brake discs and pads.... you noticed the failed bag after the car had been switched off overnight, the bag will have failed before you got home but was kept up by the compressor running, you stop and switch off and the small split in the bag will let the air out overnight... Thumbs Up Pete
Post #395919 13th Jul 2016 6:07pm
I'm with Haylands on this. Does help if you have side steps though. I train family and other users, "outside foot on the side step then inside foot into the car". Getting out they just slide, can't stop 'em! I do to Wink No-one has a problem with this.
With regard to the bags, the suspension is at work all the time when driving, if you get above 60+ it drops to motorway mode, then pumps back up to normal when you slow down. Can't see the point of dropping it to access mode (see above) will only cause extra work for the compressor/system every start up.
As Miggit says, "it is meant to be high"
Drop it to access when you need to by all means, but there is no point doing it when you don't. Twisted Evil .
Post #395934 13th Jul 2016 6:51pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Jesus Johnny guys, found this thread by accident, unless you have a good reason to lower (infirm/wheelchair etc) why do it. Even SWMBO who is small of stature has never even mentioned it, its a bloody car, get in. get out and stop moaning, I thank you Thumbs Up
Post #395955 13th Jul 2016 9:15pm
dvb247
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Im 6ft and always drop mine every time I get out of it, why, because it looks sooo much better, real bad ass, sorry if that offends Rolling with laughter Whistle Thumbs Up
Post #396121 14th Jul 2016 8:18pm
frikkadel
South Africa
What is the expected life of an airbag?
What happens when one pops? Must it get flat bedded and the AA called in?
Can pot holes make a bag pop, with the sudden down and up?
Post #396143 15th Jul 2016 6:21am
Bags have a 500 ton breaking strain, you can jump an FF no bother, I've had several feet of air under mine and landed no bother....
How long they last is a hard one, depends on so many things but 7-10 years is a good place to start...
When they go they usually get a small split and a lot of the time the compressor will keep it up till you get home... Pete
Post #396231 15th Jul 2016 3:20pm
Rosco
My front ones lasted approx 10 years and 100K miles but were rarely used i.e. access/offroad if that helps Thumbs Up
Post #396232 15th Jul 2016 3:39pm
SveinHa
Norway 2008 Range Rover Vogue TDV8 Buckingham Blue
Probably not quite comparable but after 14 years and 200k km, my p38 develpoed a small leak in one of the rear bags, changed all 4 as i felt it was time... Production date on all 4 was about 6 months before the car was born... "Plentraktoren/Garden tractor": 2008 L322 TDV8
"Project": 1990 90 County 300tdi
Post #396251 15th Jul 2016 5:38pm
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
I lower it every time I get out 2011 Range Rover Vogue SE
Post #396565 18th Jul 2016 8:12am
Alan_B
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I must be the only one that keeps it locked in motorway height then! Handles a bit better on the twisties Smile
Post #396809 20th Jul 2016 8:24am
Mr Tee
Never drop it at night cause it flashes up a bloody fault, so I don't touch it anymore..
Post #396811 20th Jul 2016 8:39am
Brian
I use mine as I have elderly parents and it helps them get in/out and also as I have a bad back and it helps me - in fact it was one of the reasons I bough the thing in the first place Cool
Post #397075 22nd Jul 2016 12:01am
Page 5 of 5 <12345
