Home > General > Do you drop the suspension when parked overnight? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Are but you've got a much newer one than my BMW tractor! My pals P38 shoots up quickly too, think that mines just lazy, like the performance Yesterday I couldn't spell Engineer... Today I are one!
5th Jan 2015 1:50am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
Even with everything working spot on the earlier ones take much longer than the later ones to raise and lower....
5th Jan 2015 1:19pm |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 |
You've got a point... JJ |
5th Jan 2015 5:18pm |
As with anything else the more you use it the quicker it wears out..... |
5th Jan 2015 5:25pm |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
or ... the less it is used, the more likely it is to have a problem when it is |
5th Jan 2015 5:28pm |
I guess its just another personal preference |
5th Jan 2015 5:42pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I use the button on the drivers door and do it as I am going into a parking space. I do it every time I use the car. My wife never does and probably slides off the seat and out the car Alex
6th Jan 2015 9:19am |
Poseidon Pete hope your well on the road to recovery So what are you trying to do? Bunny hop over obsticales Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
6th Jan 2015 11:36am |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 |
Mine is always lowered to Access height when I get out, otherwise I can't get back in very easily, being a shortie and not having side steps. |
14th Jan 2015 2:42pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Have to lower mine to the bump stops (via IID) to get my mum in! Previous cars:
14th Jan 2015 6:11pm |
Pete , your twin turbo lift pump idea, how far have you got? I'm interested, because a lot of the time when I'm hitching up to trailers, some nincumepoop has left the front of the unit too high when shunting it about with a forklift, end result jockey wheel wont go low enough So I have to mess about dropping legs and lifting wheels and picking up legs and so on or I go for the high hitch option with the suspension control and are we there yet?
14th Jan 2015 6:58pm |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 |
Interesting thread, but my question is , will you accelerate the wear on the bellows?
13th Jul 2016 2:37pm |
Handle it no problem at all, they spend all their time going up and down a bit when you drive... when they fail they split, they don't wear through so it is a failing in the material, not wearing them out....
13th Jul 2016 2:56pm |
ns2015 Member Since: 04 Jul 2016 Location: Berkshire Posts: 7 |
I always drop the suspension overnight using the drivers window switch panel. Usually works fine although it did lead to an air spring failing one morning! |
13th Jul 2016 3:46pm |
