![]() | Home > General > Do you drop the suspension when parked overnight? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
How do you know it led to it failing....??? It's impossible to say, the bags fail when they get to the end of their life, they are a replacement item like brake discs and pads.... you noticed the failed bag after the car had been switched off overnight, the bag will have failed before you got home but was kept up by the compressor running, you stop and switch off and the small split in the bag will let the air out overnight... |
I'm with Haylands on this. Does help if you have side steps though. I train family and other users, "outside foot on the side step then inside foot into the car". Getting out they just slide, can't stop 'em! I do to |
dvb247 Member Since: 22 Nov 2015 Location: Cheshire Posts: 93 ![]() ![]() ![]() |
Im 6ft and always drop mine every time I get out of it, why, because it looks sooo much better, real bad ass, sorry if that offends |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
What is the expected life of an airbag?
Bags have a 500 ton breaking strain, you can jump an FF no bother, I've had several feet of air under mine and landed no bother....
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
My front ones lasted approx 10 years and 100K miles but were rarely used i.e. access/offroad if that helps |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 ![]() ![]() ![]() |
Probably not quite comparable but after 14 years and 200k km, my p38 develpoed a small leak in one of the rear bags, changed all 4 as i felt it was time... Production date on all 4 was about 6 months before the car was born... "Plentraktoren/Garden tractor": 2008 L322 TDV8
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
I lower it every time I get out 2011 Range Rover Vogue SE |
Alan_B Member Since: 04 Jul 2016 Location: Lisburn / Northern Ireland Posts: 11 ![]() ![]() ![]() |
I must be the only one that keeps it locked in motorway height then! Handles a bit better on the twisties |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Never drop it at night cause it flashes up a bloody fault, so I don't touch it anymore.. |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
I use mine as I have elderly parents and it helps them get in/out and also as I have a bad back and it helps me - in fact it was one of the reasons I bough the thing in the first place |
