Home > Maintenance & Mods (L322) > Java Black 2002
Page 1 of 5 12345>
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
Java Black 2002
Perhaps this project requires it's own topic. Went from fever to madness and traded my P38 to broken L322. Laughing
For some reason linked images from onedrive doesn't work. Rolling Eyes
It was known that cylinder 8 had appetite for oil. It did not burn it all but kept spark plug wet and exhaust smokey. Repairs were started by previous owner and due to lack of time and motivation it was put on hold for about two years. It came to me partly disassembled and non running. All the parts were stored in the trunk. Except the ones that were lost by repair person before the previous owner. Good starting point anyway. Rolling Eyes What could possible go wrong? Well, bonnet cable broke before we got it out of trailer. Embarassed Lady of the house was very impressed of my latest purchase. Very Happy
Managed to put everything together and running. Everything seemed to be working except the exhaust smoke was huge. After removing and opening engine the problem was visible.
Piston was so tilted that it had scraped the cylinder beyond repair. Oil lock or something has happened earlier as there was "repair" work done to CCV valve and oil return tubes. Looked like "sell it fast" type repair. Very Happy
New block is from X5 with nearly same mileage 270Mm (270000km). Light lapping with Sunnen AN-30 paste and new bearings and bolts etc. New torque converter is going in as it is now accessible. And new brake lines. Smile
Post #395442 11th Jul 2016 9:31am
johnboyairey
On your shopping list should be, engine timing lock set. (Camshaft/chain location tools)
New Chain and guides, water jacket rear gaskets, and a few more, ...valley pan replacement cover, some paint stripper, and silver spray paint for the covers...and obviously new rocker gaskets.
I did my chain and guides when I bought my l322 in similar fashion to you, out with the dinosaur p38, in with a trailer, and non running filthy, snow covered L322, and the Missus, looking at new project, with a finger on lip, whilst holding her elbow, and a few remarks, not quite as enthusiastic as yours!
I also did my vanos seals. -around £100 sent from 'US besian systems' with the (included) much needed tool.
My then 140,000 mile car, is now at 165,000 miles. And it's near silent, using a tiny amount of oil, and such an upgrade to the old p38's I had before.
It will be worth the ride, and you will know you did it 'right'
And nice colour too.
Post #395504 11th Jul 2016 2:45pm
kimlahti
timing tool set *check*
new gaskets *check*
new chains *check* though old were OK to my eyes. No visible streching when compared chains.
new chain guides *check*
paint Shocked did forgot this completely. Have been concentrating on "go" more than "show". Very Happy
new vanos seals *check* telfon ring looked OK. just replacing the o-ring behind it would have been enough.
I may have exaggerated her enthusiasm. Whistle Still got to sleep inside though. Rolling Eyes
Image link test below:
[img]https://brjfpq.dm2303.livefilestore.com/y3mRCc3XEhvYmSdP3SyD9zhS1980KmUdpwOzbu5qsAbGmt8DPkN_1GfOE77zkWay8Pz2VHjm3CymxF6hGzc2w2Elg_JEuHJ8YFQ9pG0yGyYK05KL-yDQOA6AiIf8jiiUP1z3x003_9GzfQO_tKi_nBjVbJDlcitYWVrfuVS6Zh7ZQA?width=1024&height=577&cropmode=none[/img] -08 3.6 Vogue
-87 951
Post #395610 12th Jul 2016 6:59am
johnboyairey
....something else I changed whilst it was all apart, but can be done when all assembled, a very cheap part, were the vanos solenoid return check valves. Look them up, they eventually 'let by' and allow the oil in the vanos cogs, to run back, making them dry in the mornings. So, behind the protruding vanos solenoid, you insert I think an Allen head, to unscrew them, and replace. Only about £5 each x2.
I guess you had plenty of fun undoing the crankshaft nut?
P.s. I only did the rocker covers, as they were so pickled and flaking, they would have let the result down somewhat.
The rest of the engine and bay, was just steamed off. -all done I situ.
Soak your spark plugs, now, as these tend to bake themselves in, if you haven't got them out yet.
Q
Keep the pics coming! There aren't many on here of the internals under 'heavy surgery.'
Post #395615 12th Jul 2016 7:58am
kimlahti
I only changed the o-rings to those check valves. Otherwise they looked nice and clean. Smile They have M10 thread inside so they can pulled of with proper bolt.
Yes, I had too much fun. I broke the flange when undoing the bolt. Censored Laughing
Spark plugs have been off so many times and well oiled that they should be ok. Whistle
Heads have new valve stem seals and seats were lapped before assembly. New O2-sensors also coming. You are right about rocker covers. They need some fresh paint. Already have colouring kit from Furniture Clinic with Aspen and Ivory colours for interior. Smile
There are more pictures in Finnish "Rover Victims" forum. For some reason there the image links work. Rolling Eyes
http://forum.roverfriends.fi/viewtopic.php?f=31&t=10390 -08 3.6 Vogue
-87 951
Post #395620 12th Jul 2016 8:41am
johnboyairey
Yes the return check valve seals are changeable, I think that's what I did.
From your foreign forum, you look like you are having fun.
I mentioned the valley pan. These engines often suffer from water leaks, and the valley pan is often the culprit. There's a thread on here. Mine leaked, it fills the top of the inlet mani t block pockets with coolant. -it runs out the rear of the block through a tiny hole, and down the rear of engine and out through the gearbox /engine faces.
The repair is to remove, peel off old rubber gasket, prepare metal surfaces to clean metal, and either apply a bead of RTV and let it go hard, then bolt it on, as I did, -but mine has again started leaking again, a month or so on... so I have bought a replacement valley pan cover. It was about £35 sterling, and an original one is £75 sterling. (Part number Lcw000010) It has a bead already applied. The rubber gasket is not used. The bead being the improvement. It's probably a harder and more precisely laid bead, and I hope to cure my leak. I also changed all four water pipe O rings, and lubed with petroleum jelly and cleaned the pipe ends. And replaced the rear y pice gaskets. You have the opportunity to change the flywheel covered water gasket, and rear oil seal. Though I don't leak oil from rear... And I would throw in a gearbox front seal if you take that TC out.
Remember to replace the knock sensors, before you fit the water pipes, as you can't get them on otherwise.
It looks quite complicated to work on these engines, but if you use your camera, and read up, you can't really go wrong. They are very well engineered. And I'm sure you noticed how 'clean' all the oil ways are.
I might suggest you modify your thread title, to include the job you are doing, as opposed to just the car colour, as people search threads for all manner of info.
Post #395650 12th Jul 2016 10:04am
verydisco
sweet thread, subscribed ! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #395652 12th Jul 2016 10:17am
kimlahti
Valley pan is also new. Not sure if it had leaked. Valley was covered in black oily crud. Laughing Water pump had been replaced earlier as time stamp on the part was 04 and tube o-rings at rear were somewhat damaged and fixed with rtv. Rear main seal had not leaked but it is also renewed.
Yes, you are also right about TC seal. I would be stupid not to chance it same time with TC. I'll also check valve body for cracks while changing filter.
Mobile phone with camera and workshop manual is invaluable asset in garage along with minigrip bags. All screws stay safe with removed part. Cool -08 3.6 Vogue
-87 951
Post #395843 13th Jul 2016 10:26am
Hi, great thread, good to see the inside of the engine, hope I don't get to see mine though.....
You mention problems uploading photos, I have found that if you post a link from a photo hosting website then if the name of the photo is too long then it won't load... usually they have the full date and a 4 digit number, if you reduce the name to a couple of digits it works OK... keep meaning to ask Stan if this is a fault or just me....
Also on your other thread I think you asked somewhere about the lights in the side air vents, they do have the hole for a light but Land Rover decided to leave the light out as it reflected in the door mirrors...
Good luck with getting it sorted.... Thumbs Up Pete
Post #395853 13th Jul 2016 11:50am
kimlahti
Hi, you should be good if coolant and oil stays where they should be. Laughing
I use onedrive for my photos and there is function to embed images. It creates monstrous link that should be pasted to web page or blog. Example shown below. Very Happy
So no problem with side vents. That's good to know. Smile
Managed to paint those covers. No showroom level but better than before. Used some engine paint that was left over from earlier projects.
Before:
https://cj1l6q.dm2303.livefilestore.com/y3...pmode=none
After:
https://b51l6q.dm2303.livefilestore.com/y3...pmode=none -08 3.6 Vogue
-87 951
Post #396757 19th Jul 2016 4:14pm
kimlahti
Some progress again. Replaced brake line and hose to LH front. Found some surface corrosion from strut tower. Wirebrush and phosphoric acid paint should slow it down. Lot of cavity wax will be added later. Very Happy
Attached image.
Direct from phone test.
 -08 3.6 Vogue
-87 951
Post #397249 23rd Jul 2016 7:26am
kimlahti
Dropped oil from transmission and replaced torque converter with remanufactured one and seal of course. Smile I wonder if someone has been there before me. Is drilling hole in torque converter and welding it shut common practise?
There was no transmission service mentioned in the service booklet. Oil was screaming for change. Shocked
 -08 3.6 Vogue
-87 951
Post #397997 28th Jul 2016 8:07am
The links to the before and after covers don't work....
Yep, that oil looks like it could do with changing... that TC looks like a recon one by the ring of weld, I expect they drilled a hole in it to drain it before cutting it in half.... Pete
Post #398041 28th Jul 2016 12:33pm
johnboyairey
... i would say, that the weld repair, is from the 'naughty method', of replenishing gearbox fluid. ie, if you are man-enough, you drill the TC with a small drill bit, just off the welded edge, and let it drain overnight, you then rotate it just a tad, and wipe with some spriit, and mig-weld the hole. all from underneath. -in situ!
then you refill the whole gearbox.
ive done it in the past.
yes, i ran the risk.... but I was SO naughty back then! Razz
Post #398044 28th Jul 2016 12:40pm
You rebel, you..... Rolling Eyes
I thought something similar to start with but surely that's the wrong way from the weld to get to underneath with it in situ, should be the other way nearer the flex plate bolts..??? Pete
Post #398054 28th Jul 2016 2:23pm
Page 1 of 5 12345>
