![]() | Home > Maintenance & Mods (L322) > Advice please - transfer case leaking |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8513 ![]() ![]() ![]() |
IMHO, if it doesn't leave a stain on the drive overnight then it's not worth doing....
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I agree with Pete. ______________________________
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Thank you. Much appreciated. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I had a leak in my 422 that tuned out to be a crack / porosity in the casing.
Interesting. Thanks. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
get them to top it up, drive it for a month and see how much it uses. if it hasn't gone down much then just keep topping it up every so often. I bet it is just damp round the output shaft, which will slowly get worse as it wears but TBH i would keep an eye on it for a month or so and see if it gets worse. But its definitely not 8hrs labour to get the transfer box out, it just drops off the back of the gearbox and i think a cradle needs moving. But with a ramp and the right tools a garage should do it super fast. There is nothing that can't be fixed with a hammer😜😜
Where do you fill it up? Does it have a dipstick? I don't remember seeing one in the engine bay. Thx |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
IIRC the transfer box is much like the main box and has a filler level plug on one side.
yep filler plug is on the box so it is a lie on the ground job.... There is nothing that can't be fixed with a hammer😜😜
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Filler at the top of the back side, drain at the bottom of the bottom at the backside.
Very helpful. Thank you all. |
Did you sort this? |
Yes, sort of.
Good advice that
