Home > Maintenance & Mods (L322) > Advice please - transfer case leaking
RR2008HSE
I'm after a bit of advice, please.
I just had my 2008 Range Rover 4.4 petrol AJV8 NA in for a service. I had no issues with it. 208K km.
Everything done and wallet is a little lighter, however, I was told the "transfer case is leaking at the front differential".
I was told it was a slow leak and it could wait until the next service, but they recommended it be done.
Now parts are not a whole lot, but it's 8 hours work to take out the transfer case, strip it down and rebuild with new seals, gaskets, etc. I haggled and got about $350 off the quote. (Hey, it's a start.) But that still means it's Censored expensive.
Now, was discussing it with my father and he pointed out - no symptoms and no oily mess on the driveway. "Just leave it. Many cars have leaks."
My thoughts were, if it had to be done, there wasn't any point in waiting. It's not going to cure itself, and nasty things could happen if the leak got bigger.
So, ignore, or get it done?
Post #394976 8th Jul 2016 12:52am
IMHO, if it doesn't leave a stain on the drive overnight then it's not worth doing....
Also. can't see 8 hours in it, it's only 5 hours to swap a gearbox... Pete
Post #394978 8th Jul 2016 1:34am
rar110
I agree with Pete. ______________________________
Post #394981 8th Jul 2016 3:42am
RR2008HSE
Thank you. Much appreciated. Bow down I've asked for advice in a few places, and you're both with the unanimous majority. Will now try to just relax and enjoy the car... Whistle
Post #395599 12th Jul 2016 12:04am
wealy
I had a leak in my 422 that tuned out to be a crack / porosity in the casing.
Cut a long story short I had the casing welded and it didn't work. In the end I bought a casing from RRPhil and swapped all the gears over and put new seals in it and all was OK after that.
It took me about 3 hours to get the transfer box out.
Post #395608 12th Jul 2016 6:54am
RR2008HSE
Interesting. Thanks. Bow down
Post #395784 12th Jul 2016 11:16pm
get them to top it up, drive it for a month and see how much it uses. if it hasn't gone down much then just keep topping it up every so often. I bet it is just damp round the output shaft, which will slowly get worse as it wears but TBH i would keep an eye on it for a month or so and see if it gets worse. But its definitely not 8hrs labour to get the transfer box out, it just drops off the back of the gearbox and i think a cradle needs moving. But with a ramp and the right tools a garage should do it super fast. There is nothing that can't be fixed with a hammer😜😜
Post #395795 12th Jul 2016 11:33pm
RR2008HSE
Where do you fill it up? Does it have a dipstick? I don't remember seeing one in the engine bay. Thx
Post #395798 12th Jul 2016 11:36pm
IIRC the transfer box is much like the main box and has a filler level plug on one side.
I use a big plastic oil syringe when doing these jobs as it's easier than trying to tilt and squirt one of those pesky and badly designed 1ltr bottles. Discovery 4 HSE
Post #395830 13th Jul 2016 9:43am
yep filler plug is on the box so it is a lie on the ground job.... There is nothing that can't be fixed with a hammer😜😜
Post #395883 13th Jul 2016 4:27pm
Filler at the top of the back side, drain at the bottom of the bottom at the backside.
RAVE advises 0.9 litre as fill requirement, this is not a fill til it dribbles job, so you may need to drain and refill. You have to buy the oil in 1 litre cans anyway, so might as well change the lot.
The oil is hard to find other than at main dealers! .
Post #395885 13th Jul 2016 4:32pm
RR2008HSE
Very helpful. Thank you all. Very Happy Bow down
Post #395966 13th Jul 2016 11:45pm
wealy
Did you sort this?
Post #400619 15th Aug 2016 4:16pm
RR2008HSE
Yes, sort of.
I took it to a local well-known indie mechanic for a second opinion and found out the following:
The small amount of oil I had seen on the ground was oil that had been spilled onto various bits during the oil change. The clue was it was coming from the wrong place. (This oil was found close to the front wheels, centre of car. The transfer case is actually a lot farther back. It's under where the gear shift is in the car.)
The seal in question between the transfer case and the front differential was fine. I was told that this is not normally a problem with this model.
The mechanic observed that there was VERY SMALL seepage of oil from the transfer case from both the join between the two halves of the transfer case casing and where control wires enter the casing. He said both were EXTREMELY small and nothing to worry about.
I was further told that "replacing the seals" is not a "routine" fix from the workshop manual. It seems that the official procedure is "problem with transfer case - remove and replace".
This mechanic is VERY FUSSY about everything being just right. He simply noted down to check the transfer case oil level at the next service and was confident that a check every 5000 km was more than sufficient.
Wealy, I hope that helps. Very Happy
Post #400657 15th Aug 2016 10:09pm
wealy
Good advice that
Post #400674 16th Aug 2016 7:59am
