Home > General > Transmission fluid leaking
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Left my car in the car park for 5 days until today, when I went to the car, I noticed that there was a lot of oil on the floor under the car. Luckily one of the guys working in the car park went under to car to trace the leak and he said that the oil is coming from the transmission.
Anyone else had this problem before?
I need to order some gaskets and small parts from L.R UK. I emailed the parts department of Lookers P.Royal earlier today but never got a response. Can someone give me a contact so I can order the parts I need for my car? (BTW I am in Malaysia and L.R Malaysia won't sell me any parts cos i did not buy my car from them! silly but true!)
thanks! '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #37968 22nd Nov 2010 6:36pm
dantheman
Could try the parts guys at Hillendale - very hepful whenever I've used them:
PARTS SUPERVISOR
Stephen Cushing
Tel: 01282 723774
Fax: 01282 723724
Email: parts@hillendale.co.uk
Hope this'll do. Thumbs Up
Post #37995 22nd Nov 2010 7:25pm
mercuryf1
That's great... thanks!
Thumbs Up '01 1.8i Freelander. Grey/ grey
Post #38012 22nd Nov 2010 7:57pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I had a small amount of transmission fluid on the driveway and when I got underneath the pipes from the gearbox to the cooler were badly corroded and weeping fluid.
They were so corroded I reckoned if I touched them they would fall apart.
Was working away from home at the time and was going to get the pipes and take them home on the plane with me but they are quite a length and are preformed.
In the end got the dealer to change them and the gearbox sump plate as well.
Ian
Post #38348 23rd Nov 2010 12:46pm
mercuryf1
I suspect it may be a bigger job then I initially anticipated cos there is a lot of oil under the car. maybe it's best I get a mechanic to come over to check it out so I can order the parts from UK. Thanks for the tip Ian! '01 1.8i Freelander. Grey/ grey
Post #38357 23rd Nov 2010 12:55pm
mercuryf1
Ian
How much were you charged for the whole repair? Replacement of sump plate alone was it expensive? '01 1.8i Freelander. Grey/ grey
Post #38758 24th Nov 2010 8:39am
IanV8
Total cost was £774 inc labour.
That was pipes, cooler, sump plate, fluid, gaskets and fittings/seals.
I think the sump plate was only £25 but receipt is at home, will check tonight.
Ian
Post #38949 24th Nov 2010 1:00pm
mercuryf1
Ian, was it not necessary to replace the gearbox filter also?
(as in http://cgi.ebay.co.uk/LANDROVER-RANGE-ROVE...721wt_907) '01 1.8i Freelander. Grey/ grey
Post #39068 24th Nov 2010 5:02pm
If the sump is off you are as well changing the filter at the same time. That is a good price for the one on ebay as it will cost you around £100 from LR
Post #39098 24th Nov 2010 6:17pm
IanV8
Yes the filter was changed at the time.
Forgot to look at receipt, will try to remember tonight.
Ian
Post #39475 26th Nov 2010 8:45am
mercuryf1
i was also told by my mechanic that the transmission needs some special expensive gearoil ... and lots of it too@! I wonder if that is his way of gently telling me to expect a big fat bill?!! '01 1.8i Freelander. Grey/ grey
Post #39481 26th Nov 2010 9:31am
The ATF is around £15.00 per litre
Post #39485 26th Nov 2010 9:51am
mercuryf1
Going to collect the car now. Will the the damage very soon. '01 1.8i Freelander. Grey/ grey
Post #39486 26th Nov 2010 9:54am
Trousers down time, this will hurt you more than me Big Cry
Post #39490 26th Nov 2010 9:59am
IanV8
Main parts
Pan £55.35
Gasket £9.33
Tube £29.71
Pipe £28.60
Plate £11.85
Oil cooler £142
Oil £67.80
Coolant £27.63
Labour £280
Total £774.02 inc small O rings and seals & vat.
Unless the plate is the filter then maybe it was not changed.
Ian
Post #39553 26th Nov 2010 3:58pm
