Home > General > Transmission fluid leaking |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 |
Left my car in the car park for 5 days until today, when I went to the car, I noticed that there was a lot of oil on the floor under the car. Luckily one of the guys working in the car park went under to car to trace the leak and he said that the oil is coming from the transmission.
22nd Nov 2010 6:36pm |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 |
Could try the parts guys at Hillendale - very hepful whenever I've used them:
22nd Nov 2010 7:25pm |
That's great... thanks!
22nd Nov 2010 7:57pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I had a small amount of transmission fluid on the driveway and when I got underneath the pipes from the gearbox to the cooler were badly corroded and weeping fluid.
23rd Nov 2010 12:46pm |
I suspect it may be a bigger job then I initially anticipated cos there is a lot of oil under the car. maybe it's best I get a mechanic to come over to check it out so I can order the parts from UK. Thanks for the tip Ian! '01 1.8i Freelander. Grey/ grey
23rd Nov 2010 12:55pm |
How much were you charged for the whole repair? Replacement of sump plate alone was it expensive? '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
24th Nov 2010 8:39am |
Total cost was £774 inc labour.
24th Nov 2010 1:00pm |
Ian, was it not necessary to replace the gearbox filter also? (as in http://cgi.ebay.co.uk/LANDROVER-RANGE-ROVE...721wt_907) '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
24th Nov 2010 5:02pm |
Yes the filter was changed at the time.
26th Nov 2010 8:45am |
i was also told by my mechanic that the transmission needs some special expensive gearoil ... and lots of it too@! I wonder if that is his way of gently telling me to expect a big fat bill?!! '01 1.8i Freelander. Grey/ grey
26th Nov 2010 9:31am |
The ATF is around £15.00 per litre |
26th Nov 2010 9:51am |
Going to collect the car now. Will the the damage very soon. '01 1.8i Freelander. Grey/ grey
26th Nov 2010 9:54am |
Trousers down time, this will hurt you more than me |
26th Nov 2010 9:59am |
Main parts
26th Nov 2010 3:58pm |
