Home > Technical (L322) > Self levelling suspension inactive |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8066 |
Was away for the weekend off roading up near Newcastle, on the way home had a bong of doom and up pops
4th Jul 2016 3:01pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2251 |
Hi Pete as you know I just replaced a load of suspension parts too and from this one and my p38 have noticed that for me anyway the rears went first then the fronts about 6 months later
5th Jul 2016 6:34am |
Digger7820 Member Since: 04 Jan 2016 Location: Brigg Posts: 28 |
I am sure you will sort it Pete
5th Jul 2016 7:00am |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
Water in the connectors may be? |
5th Jul 2016 2:36pm |
Oh it's not an issue, just putting some info on for others as it's a weird fault to get with a failing sensor, usually the corner at fault goes all the way up or down.....
5th Jul 2016 11:25pm |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Pete, when you change the sensors, does the suspension need re calibrating (as per the Disco 2) or will it be ok? |
5th Jul 2016 11:36pm |
To be honest I didn't bother with the other two as it was close enough... Probably do it now I've changed them all, only takes 10mins with the IID tool once you get your head round it... Pete
5th Jul 2016 11:49pm |
Thanks. I had a similar issue pulling the tin tent at spring bank. Pulled out of a service station a bit quick and got all the bongs. No performance issues just the message "Only normal ride height available" or something similar and all the EAS led's out. Got to the site and switched it off while I booked in and when I re started her everything was back to normal and has been since. |
5th Jul 2016 11:55pm |
It's very easy, you don't even have to jack it up or take a wheel off... stick it in off road height, open a door (not the boot) and also stick an axle stand underneath just to be safe, find the sensor, it has an arm fixed to the lower suspension arm, unplug the electrics, remove the nut from the arm, remove the two screws holding it on and remove it, refit the same way, you have to be a bit careful with the wiring plug, they get hard and are difficult to pull off, if they break or the plugs look corroded you can buy the plug with a short loom from the dealer and splice it into the old loom. The wiring is tye wrapped to the subframe and it can be easier to cut them off and refix after..
6th Jul 2016 7:09pm |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 |
Hi Pete and thanks. Apologies for hijacking the thread.
7th Jul 2016 6:47am |
Sorry didn't read it properly, if one is out then change it and I suppose changing the others to preempt any further issues in your neck of the woods would be prudent...
7th Jul 2016 10:29am |
Thank Pete, good advice and my leaning too.
8th Jul 2016 5:07am |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
I also had a "height sensor activity invalid" today, but the EAS inactive message disappeared after turning car off/on. Does this mean I need a new sensor?
8th Jul 2016 8:25am |
chex, sorry missed your post, I have now changed all 4 of mine, they all gave a warning before failing completely...
18th Aug 2016 9:13pm |
