Home > Technical (L322) > Self levelling suspension inactive
Was away for the weekend off roading up near Newcastle, on the way home had a bong of doom and up pops
"Selflevel susp inact" and "max speed 35mph" and all the EAS lights went out, so as usual I totally ignored it and drove 100 miles home at normal speed and everything worked fine, got home and got out of it, shut the door and it levelled itself...!!!
Got round to plugging the IID in today and it is showing front left and rear right height sensor faulty but now the EAS light is back on and everything works fine, goes up to off road and down to access no problems and readings from height sensors are all good...
It does make some sort of sense as I have changed the other two sensors within the last year so the two faulty ones are originals, just funny it hasn't dropped or raised a corner and it now works fine....
Anyway, thought I'd put the info on here for others if needed... Two new height sensors ordered and it should be fine...!! Pete
Post #394391 4th Jul 2016 2:01pm
Sandyt
Hi Pete as you know I just replaced a load of suspension parts too and from this one and my p38 have noticed that for me anyway the rears went first then the fronts about 6 months later
I know you will sort it Thumbs Up
Post #394538 5th Jul 2016 5:34am
Digger7820
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
I am sure you will sort it Pete
Graham Range Rover vogue Td6
Land Rover Defender TD5
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Series lll short wheel base
Super 7 kit car
AC Cobra (still got)
Post #394539 5th Jul 2016 6:00am
markcartlidge
Water in the connectors may be?
Post #394598 5th Jul 2016 1:36pm
Oh it's not an issue, just putting some info on for others as it's a weird fault to get with a failing sensor, usually the corner at fault goes all the way up or down.....
The sensors are well below the maximum wading depth so are waterproofish, these will just be worn out, after all they do move all the time you are driving so will give up sooner or later... Thumbs Up Thumbs Up
New ones turned up today, probably fit them tomorrow... Pete
Post #394707 5th Jul 2016 10:25pm
steadyaway
Pete, when you change the sensors, does the suspension need re calibrating (as per the Disco 2) or will it be ok?
Post #394713 5th Jul 2016 10:36pm
To be honest I didn't bother with the other two as it was close enough... Probably do it now I've changed them all, only takes 10mins with the IID tool once you get your head round it... Thumbs Up Thumbs Up Pete
Post #394716 5th Jul 2016 10:49pm
steadyaway
Thanks. I had a similar issue pulling the tin tent at spring bank. Pulled out of a service station a bit quick and got all the bongs. No performance issues just the message "Only normal ride height available" or something similar and all the EAS led's out. Got to the site and switched it off while I booked in and when I re started her everything was back to normal and has been since.
Post #394717 5th Jul 2016 10:55pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi Haylands,
Any chance of a little rundown on how to change the Height Sensors?
Thinking of changing my rear ones, the near side is raising about 15mm higher than the spec stated.
Cheers, Jerry THIS WRECKAGE
Post #394725 6th Jul 2016 5:53am
It's very easy, you don't even have to jack it up or take a wheel off... stick it in off road height, open a door (not the boot) and also stick an axle stand underneath just to be safe, find the sensor, it has an arm fixed to the lower suspension arm, unplug the electrics, remove the nut from the arm, remove the two screws holding it on and remove it, refit the same way, you have to be a bit careful with the wiring plug, they get hard and are difficult to pull off, if they break or the plugs look corroded you can buy the plug with a short loom from the dealer and splice it into the old loom. The wiring is tye wrapped to the subframe and it can be easier to cut them off and refix after..
Fronts are very similar... Thumbs Up
Don't think I'd bother to change them if they are not broken though, if it's out of spec then get it re set Pete
Post #394804 6th Jul 2016 6:09pm
Road Stone
Hi Pete and thanks. Apologies for hijacking the thread.
It does appear simple, when I get back to Uganda, I'll take a look.
Are you suggesting given that one sensor is out not to bother changing at this time?
I can deflate the system with Hawkeye and then see what happens.
Post #394854 7th Jul 2016 5:47am
Sorry didn't read it properly, if one is out then change it and I suppose changing the others to preempt any further issues in your neck of the woods would be prudent...
The IID tool can turn the system off and then inflate or deflate specific corners so if you have a sensor fail miles from home you can still level the FF and drive it, very handy feature... Thumbs Up Pete
Post #394871 7th Jul 2016 9:29am
Road Stone
Thank Pete, good advice and my leaning too.
Post #394982 8th Jul 2016 4:07am
chex
Kenya
I also had a "height sensor activity invalid" today, but the EAS inactive message disappeared after turning car off/on. Does this mean I need a new sensor?
Cleared fault, hasn't come back yet. 2004 L322 V8
Post #394992 8th Jul 2016 7:25am
chex, sorry missed your post, I have now changed all 4 of mine, they all gave a warning before failing completely...
Roverlord, that will clear some faults but I doubt it will repair a hall effect sensor which is what the height sensors are... they move all the time you are in motion and just wear out...
What you have described is the procedure to reset the steering angle sensor when you have disconnected the battery... Thumbs Up Pete
Post #401064 18th Aug 2016 8:13pm
